It is currently Mon May 04, 2026 8:43 am
PostPosted: Tue Jan 11, 2011 3:57 am
are the rings that come on the Mahle kits any good for the big stroker motors or is it better to get Grant, Total Seal, Wiseco or maybe some other brand?
PostPosted: Tue Jan 11, 2011 9:22 am
We always used total seal 2nd rings and mahle tops and oils i believe. or it was total seal tops and mahle 2nds and oils. my brain is not coperating with me right now.
PostPosted: Tue Jan 11, 2011 9:31 am
Total seal all the way
PostPosted: Tue Jan 11, 2011 10:15 am
You can either buy just the 2nd total seal ring for about $75.00 or you can get the full total seal set for about $100.00. I run the full total seal set.
PostPosted: Tue Jan 11, 2011 9:03 pm
Total seals supposedly give hp by allowing minumum possible compression leak. I could feel no difference when I switched to them on a motor that only had two rides on it. Also, some people feel the total seal rings will wear a cylinder faster than Mahle rings.
PostPosted: Wed Jan 12, 2011 10:48 am
i ran them , and switched back to mahle rings , they will wear out the cylinders in a high compression application to where you have to replace them once it starts smoking & usually eliminates being able to just re-ring a piston , but they last a little longer than mahle's ( imo )!!
PostPosted: Wed Jan 12, 2011 8:21 pm
I run mahle top & oil ring & total seal 2nd ring . Have race the eng 2 year with the same cylinders . You may have to file the rings for proper ring gap.
PostPosted: Fri Jan 14, 2011 5:01 pm
thanks guys for all the input :D
PostPosted: Tue Jan 18, 2011 10:34 pm
Total seal 2nd .....Ran them in a 2387 for 10 years used the same jugs freshened it a time or two but never replaced the jugs. Every Time I tried Mahle it smoked after a while
