It is currently Tue May 05, 2026 10:30 am
PostPosted: Wed Oct 06, 2010 9:01 pm
i bought a set of new v treads for 300 dollars and the name on the tire says ngk
im grooving the so i can get ready for d&k
daes anyone know it this is a good tire or not?
PostPosted: Wed Oct 06, 2010 9:15 pm
are they 23 deg? and what ply?
lets just ride
PostPosted: Wed Oct 06, 2010 9:46 pm
there 8 ply and idk if their 23 degree but they are a really soft tire
PostPosted: Thu Oct 07, 2010 12:34 am
more info please, like where to buy, cost, etc........
PostPosted: Thu Oct 07, 2010 10:40 am
Please let me know where to get some?
Life is not about reaching the grave in a well perserved body but rather to slide in sideways yelling "HOLY S@#: what a ride"!
PostPosted: Thu Oct 07, 2010 8:27 pm
i bought them last week for 300 new and ill get the number of that place i got them at
when i grove those tires do i need to cut all the way to the wires or leave some rubber over the wires
PostPosted: Thu Oct 07, 2010 8:34 pm
ask koko!!!! i cut my 8 plys all the way to the cords though, and it made a huge diff
lets just ride
PostPosted: Thu Oct 07, 2010 8:40 pm
does it hurt the tire if you snib the corsd some, i messed up and cut about a quarter inch of the cords
PostPosted: Thu Oct 07, 2010 8:51 pm
im sure its not good for em but dont worry i made the same mistake twice on mine :shock: :shock: but i havent had any trouble yet
lets just ride
PostPosted: Thu Oct 07, 2010 8:53 pm
good luck, i had 16 hours in cutting my set
lets just ride
PostPosted: Thu Oct 07, 2010 9:09 pm
did u use a little blade or something, i goin to get a3/4 blade to cut mine with
PostPosted: Thu Oct 07, 2010 9:21 pm
i started with a 1/4 and went to a half, i tried the 3/4 but it was a bit$$ to push so i stuck with the half inch
lets just ride
PostPosted: Thu Oct 07, 2010 11:42 pm
Heat the rubber with a hand torch before you cut it. also turn the blade around backwards so you can pull it. so much easier than pushing
PostPosted: Fri Oct 08, 2010 10:37 am
Hmm! never thought about pulling the blade. Might be less chance of cutting the chords that way. Gonna try it on my spare set of Boggers.
PostPosted: Fri Oct 08, 2010 4:43 pm
still need some pics of these,,,take a pic with your phone and forward to 256-656-5333
PostPosted: Fri Oct 08, 2010 5:35 pm
Make your start of the pull slowly go till you feel it touch cords. then ease up a little and go. that will make it a ton faster....
PostPosted: Sat Oct 09, 2010 2:04 am
still not enough info :|
ive hunted ngk tires, ngk flotation tire, ngk bar tread, and ngk v tread and have had nothing ngk come up but spark plugs :roll:
PostPosted: Sat Oct 09, 2010 10:09 am
whatever they are there not gonna be a firestone tire,dont waste your money on anything else u wont be happy,denman ditch witch was about 120 a pcs,but they stil suck even if they are cheap
PostPosted: Sat Oct 09, 2010 1:30 pm
thae name on the tire is bkt, idk what i was thinking when i said ngk
and ill get pictures on here as soon as i can
PostPosted: Sat Oct 09, 2010 5:08 pm
i think these are the tires hes talking about
http://www.bkt-tires.com/SearchDetailTy ... ssPly/Bias
PostPosted: Sat Oct 09, 2010 8:12 pm
yea thats them
cron
