It is currently Sun May 03, 2026 8:22 am
Post new topic Reply to topic  [ 187 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 8  Next
 Post subject: Re: Donor car
PostPosted: Wed Aug 27, 2008 8:49 am
I'm tickled you made it here numby,,,most of the stuff you mentioned is Greek to me,,, . But there are some real smart guys here that will understand. I also made an EGR block off plate but am a little concerned what the ecu will think of that,,, guess I will find out :?
PostPosted: Wed Aug 27, 2008 4:11 pm
haha, well, short version is. if you need more power, send your ECU off to ECUtune to have it reprogrammed. no need to re-wire almost anything.
you'll get a code, but it'll run just fine. just make sure that check engine light isn't visible from the driver's seat, cause it'll be on all the time :D
Subaru wiring: NumbchuxConversions
PostPosted: Sun Sep 07, 2008 9:10 pm
Here is the pan welded,,, gonna put some shake up paint on it and bolt it down soon
PostPosted: Sun Sep 07, 2008 9:36 pm
That looks a pan/skid plate! nice work
PostPosted: Sun Sep 07, 2008 9:56 pm
3/16",,my son welded it for me :wink:
PostPosted: Mon Sep 08, 2008 1:15 am
looks good!
Mike
Got Honda?
PostPosted: Mon Sep 08, 2008 6:27 pm
looks good buy i got a stupid question what is the golf ball for just to keep debris out off to ports i seen them in some of your other picture
drive it like you know how too fix it
PostPosted: Mon Sep 08, 2008 7:32 pm
Remember ,,no questions are stupid,,,just the answers..Your guess is correct,, all I could grab at the time I was doing some washing,,,I was wondering how long it would take someone to comment on that,,, :wink:
PostPosted: Mon Sep 08, 2008 11:01 pm
I just thought you were playing the back nine at the country club later :lol:
PostPosted: Tue Sep 09, 2008 6:24 am
My wife and kid play,,,I barely can play the radio :roll:
PostPosted: Tue Sep 09, 2008 9:13 am
FOUR
PostPosted: Wed Sep 10, 2008 10:48 pm
Got me an aluminum alternator bracket..Steve gave me the idea and I found one local,,also got the pan painted
PostPosted: Sat Sep 13, 2008 9:48 am
Honda stainless headers from ebay for $100 shipped,, Instigator is making Suby flanges ,,,a little modifying and they will be ready to mount
PostPosted: Sat Sep 13, 2008 10:09 am
You know Marty, that would look awesome with a turbo on each side! :shock: :mrgreen:
PostPosted: Sat Sep 13, 2008 11:11 am
I may put twin turbos on just for looks and sound...and remain NA,,,,seriously,,,,,,,,,,,,,really ,,,seriously,,,
PostPosted: Sat Sep 13, 2008 1:21 pm
fill those headers full of wheel bearing grease and they will not turn blue smokes like hell for awile my buggy header is three year old still not turn blue . i see you sill found use for the golf balls :D
PostPosted: Sun Sep 14, 2008 1:42 am
I know a guy in the process of putting twin turbos on his 3.3 (in a subaru) in a configuration very much like that.
PostPosted: Sun Sep 14, 2008 10:13 am
Will the stock bottom end hold that much power?
PostPosted: Sun Sep 14, 2008 10:21 am
Numbchux can answer that question,,,all I know is the thing has 7 mains,,,,I'd guess yes :twisted:
PostPosted: Sun Sep 14, 2008 2:22 pm
drop turbo pistons in it to lower the compression ratio (same bore and rod design as the 2.2 4-cyl, so 2.2 turbo pistons drop right in, just need 6), and it's been pushed up in the 500awhp range. I've never seen one successfully twin turbo'd, but one big one, yea.
the guy I'm working with (I did the wiring) is doing a complete build though, reinforcing the block, blueprinting and balancing the whole assembly to 10k rpms, couple good sized turbo's with intakes right behind the headlights (remove the lights for track days). he's shooting for the 8-900awhp range :twisted:
when you think about it, the 2.2 4-cyl that the 3.3 was based off of is regularly pushed into the 600awhp range with a DOHC conversion (3.3 is already DOHC). and that force is now spread out over more cylinder wall surface area, 2 more main bearings, etc......yea, it's possible.
alright, I'm done hijacking :lol:
PostPosted: Wed Oct 01, 2008 10:16 pm
On the right is the Honda headers I got cheap on ebay with the flange Instigator made,,on the left is the modified header for the Subaru 3.3 ready to weld up.
PostPosted: Wed Oct 01, 2008 10:47 pm
looks good marty, show a close up the modified one 8)
Mike
Got Honda?
PostPosted: Thu Oct 02, 2008 8:27 pm
PostPosted: Thu Oct 02, 2008 10:40 pm
wow, nice work Marty!! Those look great! 8)
-Dakotah/ jelly jr. :mrgreen:
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Sat Oct 04, 2008 4:50 am
WOW!!!!!! way cool!!
