It is currently Sun May 03, 2026 4:56 pm
PostPosted: Thu Jun 12, 2014 12:19 pm
What are you guys doing to run your throttle cable to the throttle body on the ecotec.
And does anyone have a part number for a comparable pump that will run that motor from autozone? So that I can get a warranty with what I buy
PostPosted: Thu Jun 12, 2014 2:53 pm
i made my own cable and my fuel pump came from summit. Summit brand i think i paid about 85.00 and its still going 4 years later.
PostPosted: Thu Jun 12, 2014 3:11 pm
Can I get a picture of how you have it hooked to your throttle body
PostPosted: Thu Jun 12, 2014 7:24 pm
The tb is operated electricly by a motor on the side of it,which is controlled by the ecm. I used a stock cobalt pedal which was controlled through a cable to accelerator pedal that we normaly use on a buggy. I wanted to keep the cobalt pedal dry.
PostPosted: Thu Jun 12, 2014 11:43 pm
If he has a 2.2 ecotech he probably has a cable operated version
PostPosted: Thu Jun 12, 2014 11:52 pm
I do have cable. Figured out that one. Used the dogleg off stock vw cable imto where the ball on stock ecotec goes. Now just need fuel delivery.
PostPosted: Fri Jun 13, 2014 12:09 pm
What do you guys think about using the E2000 pump? Heard it doesnt pull real good but pushes real good
PostPosted: Fri Jun 13, 2014 12:23 pm
I've had a E2000 pump on my buggy for at least 4 years trouble free so far.
Sent from my SM-N900P using Tapatalk
PostPosted: Fri Jun 13, 2014 12:41 pm
E2000 eBay around 35 bucks
PostPosted: Fri Jun 13, 2014 12:52 pm
What motors you running them on ?
PostPosted: Fri Jun 13, 2014 1:13 pm
viewtopic.php?t=16085
This is my hunt. I really like the ac delco I picked up and it has more top end now so I think the summit pump was falling off some or had something to do with it coming apart. :?
PostPosted: Fri Jun 13, 2014 1:25 pm
Mine is a 2.2 ecotec.
Had a summit, did not last.
Now a E2000, so far its been good and a lot less noise.
Do you have a returnless fuel setup?
If so this may save you some $.
Fuel filter and regulator in one.
http://www.speedwaymotors.com/LS1-Fuel- ... 41793.html
Norm
PostPosted: Fri Jun 13, 2014 2:07 pm
That is the same as a fuel filter you can get at AutoZone for a 2000 jeep grand 4.0 set at 55psi
PostPosted: Fri Jun 13, 2014 4:29 pm
Maybe, I don't know.
I wish I had seen a filter like those.
I ended up making my fuel rail a return style and then adding a reg.
I could of save a bunch going with a reg/filter.
PostPosted: Sat Jun 14, 2014 7:22 pm
1996 ford f150 fuel pump cheap inline pump
PostPosted: Tue Jun 17, 2014 11:12 am
Ended up going with a e2000 pump. 85 bucks in a lifetime warranty.
