It is currently Sun May 03, 2026 9:41 am
 Post subject: 044 Heads Questions
PostPosted: Tue Oct 29, 2013 10:44 am
I am building an 1835cc engine with a c35 scat camshaft and dual Weber 44s. I am wondering if the 044 heads will work on this particular setup. I am fairly new to VW engines and am wanting to learn more, so this is why I'm asking this question. My brother is running 044 heads on his 1915cc, type 3 turbo setup, juts wanted to put that out there.
 Post subject: Re: 044 Heads Questions
PostPosted: Tue Oct 29, 2013 12:14 pm
The 044 is the casting of the head it can come with 40 x 35.5 valves and up to the 46 x 37 ultra wedge ports. It depends on what heads you have.
Travis
PostPosted: Tue Oct 29, 2013 7:39 pm
these are 044 wedge port heads that I am getting ready to put on a 2500
PostPosted: Wed Oct 30, 2013 9:03 pm
If I were building that engine I would opt for the los panchito CNC ported 044's. I also would run no bigger than dual 40mm carbs.
PostPosted: Thu Oct 31, 2013 11:51 am
thanks for your input guys i am learning more and more about VW engines
PostPosted: Sat Nov 09, 2013 10:52 pm
You can use your Weber 44's on the motor you are building. Just choke them down a little bit and they will work great. That's all you have to do. Save your old chokes (venturis) incase you want to build a big motor soem day you can switch them back.
