It is currently Sun May 03, 2026 4:53 pm
 Post subject: Help with beadlocks
PostPosted: Wed Feb 02, 2011 6:28 pm
I Just got steel beadlock kits for my 15in rims. Wondering if anyone could give me advice on getting this done myself. I'm not sure on what needs to be done, I'm hoping its not too difficult. Worst case maybe there's someone around here that can do them for cheap? thanks.
 Post subject: Re: Help with beadlocks
PostPosted: Thu Feb 03, 2011 2:08 am
the ones ive seen you just lay the inside ring down in the face of the wheel and weld up the gap between it the lip of the wheel, however if its not a good, clean, and solid weld you may have to seal it with silicone to keep from leaking
PostPosted: Thu Feb 03, 2011 2:33 am
ok thanks, im going to give it a try. Ive heard from some people you have to cut the bead ring out of the rim, but idk.
PostPosted: Thu Feb 03, 2011 3:30 am
http://www.youtube.com/watch?v=LgyMUENdA_U
I find it easy to fit beadlocks than to make the forum's YouTube button to work!! :?
PostPosted: Thu Feb 03, 2011 1:11 pm
nice, thanks that was a lot of help
