It is currently Tue May 05, 2026 4:04 am
 Post subject: Boggers?
PostPosted: Mon Jan 24, 2011 8:40 pm
Is there different types of boggers? The reason I ask is, I have a set I am going to regroove and I think they are 4ply. But I have seen some boggers with alot of meat cut off, like for instance the one's on Firebugs buggy. I was just wondering how much i can cut off my tires, and if there are two differen't kinds of boggers? I plan on going at least to the 1st cord or further if permitted.
 Post subject: Re: Boggers?
PostPosted: Mon Jan 24, 2011 8:46 pm
Mine were cut per my request,,,but after loosing 2 lugs I might rethink that.
PostPosted: Mon Jan 24, 2011 8:53 pm
I already have a couple of seasons on these, so more tread period will be an improvement. I have a set of v tread to run also, but I like ground clearance,and traction. are your tires four ply marty?
PostPosted: Mon Jan 24, 2011 9:12 pm
mine are the 16-35-15 and are 6 ply.
http://www.intercotire.com/tires.php?id=13&g=1
PostPosted: Mon Jan 24, 2011 9:24 pm
i cut mine till i saw cord and they was same as firebugs and did good they was half warn out when i cut and made them almost like new
PostPosted: Mon Jan 24, 2011 10:04 pm
im with firebug, i cut a new set of stones to the cord and after about 5 rides at pickwick i lost almost half the lugs off one and several off the other, just my 2 cents...
PostPosted: Mon Jan 24, 2011 10:38 pm
here is a chart for sizing of boggers. it appears that the tread is minimun 6ply and the side wall are 4ply
- Sigmund Freud
- Antonio Meloni
PostPosted: Mon Jan 24, 2011 10:40 pm
must be an echo in here :wink:
PostPosted: Mon Jan 24, 2011 10:43 pm
i would say if they are new just cut off the small lugs but if yours are used go on and cut to cords did mine that way and had no problems loosing parts of my tire
PostPosted: Mon Jan 24, 2011 10:55 pm
kantgetrite stay out behind those trees , you will save your tires that way, you know power braken it to hold all that tenn, POWER
PostPosted: Tue Jan 25, 2011 10:00 am
thats what happens when ya dont get enough sleep :lol:
- Sigmund Freud
- Antonio Meloni
PostPosted: Tue Jan 25, 2011 11:37 am
I have already cut out the small lugs and grooved the tire some already. I guess mine are also six ply must have been looking at the sidewall. Guess I'll get the groover and go to town on them thangs this weekend 8)
PostPosted: Tue Jan 25, 2011 1:11 pm
Ya gotta love them cut boggers!
PostPosted: Tue Jan 25, 2011 1:42 pm
I sure don't envy that job, let us know how many days it takes.
PostPosted: Tue Jan 25, 2011 11:57 pm
dont cut them all the way to cords,,,about 1/16 of an inch from the cords and they will last forever,,,all we run down here is boggers,if u cut to the cords a small sharp rock and u got to put a boot/patch in tire
PostPosted: Wed Jan 26, 2011 2:25 pm
Thanks for the input guys. chris I look forward to riding pickwick this year I hear it is an awesome place to ride. And yes I do dread the grooving process but is has to be done. These boggers can't be worse than the dico v treads 8 ply that I cut to the cords this past summer :shock: At least I HOPE NOT :!:
cron
