It is currently Mon May 04, 2026 3:25 pm
PostPosted: Mon Jan 17, 2011 5:21 am
Can anyone suggest a spring rate for the rear of my mid engine buggy? I've got some 16" long coilovers coming, but not sure where to start on spring rate
PostPosted: Mon Jan 17, 2011 6:38 am
you need the weight of each rear wheel and then just call spring or shock company and they should be able to help you out
PostPosted: Mon Jan 17, 2011 8:24 am
Tried that when I ordered the coilovers, but because this sort of application is unheardof here in the UK they couldn't help, other than "buy a 100lb and try, if its too soft buy some stiffer ones"
PostPosted: Mon Jan 17, 2011 9:49 am
Give Downsouth Motorsports a call, he is the best guy to talk to when it comes to coilover shocks, Kings, Foxs, Sway-a-Ways brand shocks, here is a link to his website and phone number.......http://downsouthmotorsports.com and the number is toll free unless you order since you're in England, hopes this helps.
PostPosted: Mon Jan 17, 2011 11:15 am
Spring rate calculators.
http://f-o-a.com/
http://www.swayaway.com/TechRoom.php
PostPosted: Mon Jan 17, 2011 11:41 am
Ahhh awesome Mike.. I'll dig out the corner weight gage later...
PostPosted: Mon Jan 17, 2011 11:55 am
Fwiw, for the comping we aim at 3G of spring rate over the travel at the rear - i.e, if one rear corner has 500lb of weight on it and 10" of travel, I'd aim for a wheel rate of about 150lb/inch, if the coilovers hit ~8" down the arm then about 240lb/inch at the spring depending on the angle of the coilovers.
Depends on what you're doing really though, how much travel you have, whether you want a progressive setup, what the rear unsprung weight is, damping....... :lol:
I tend to go the opposite way to a lot over here and the more travel that becomes available the stiffer I'll go on the main spring - but make it shorter and run a longer, softer tender and let damping and extra droop travel do the work over the washboard stuff.
PostPosted: Fri Jan 28, 2011 4:42 am
I used Mike's F O A calculation and came up with 220lb, so got some Faulkners 200lb springs and they're spot on with about 1/4 of preload.. I was so pleased I had to take it for an illegal night time blast :twisted:
