It is currently Sun May 03, 2026 10:42 pm
 Post subject: Ecotec Radiator
PostPosted: Tue Jan 11, 2011 10:49 pm
Would this radiator on ebay be big enough to keep an ecotec cool?
http://cgi.ebay.com/ebaymotors/96-00-HO ... ccessories
 Post subject: Re: Ecotec Radiator
PostPosted: Tue Jan 11, 2011 11:01 pm
I dont know if this will help but they are running them on subi's and they work.
PostPosted: Tue Jan 11, 2011 11:08 pm
Thanks, I am picking up my donor car on Saturday, so I am wanting to get all the parts together for the conversion.
PostPosted: Tue Jan 11, 2011 11:31 pm
I would think that would work. I,m using the stock ecotec radiator from the car i got engine from. Its a single core and maybe 3/4 inch thick.
PostPosted: Tue Jan 11, 2011 11:44 pm
thats what i run on my suby and it works fine wildcat
lets just ride
PostPosted: Wed Jan 12, 2011 12:04 am
are you up gradeing the tranny?
lets just ride
PostPosted: Wed Jan 12, 2011 9:06 pm
I am going back to the 6 rib. I have 2 of them needing carriers. One of them has never been in a buggy. I just did not have enough power with the 1915 to run them wth my 33" tires.
PostPosted: Wed Jan 12, 2011 11:53 pm
cool! you wont have a power issue now :wink:
lets just ride
PostPosted: Thu Jan 13, 2011 8:35 am
I tried a Radiator like that on my subie and it ran hot I went with a 97 jeep radiator does fine now..
"I got this..."
PostPosted: Thu Jan 13, 2011 9:30 am
I have been running a Fierro radiator for years. The inlet and outlets are oriented correctly and it is very ample for my 3.3. They are an easy size to locate too. Just another one to consider.
PostPosted: Thu Jan 13, 2011 11:03 am
I also use a Jeep Cherokee Radiator.
http://i1101.photobucket.com/albums/g42 ... C00079.jpg
PostPosted: Thu Jan 13, 2011 11:15 pm
i stay in the gas with that rad and have never had a temp issue! i did cut the center outta my thermostat and after hours of hard rideing my temp never got above 195 with my fan on :wink: but if the jeep rad is better id check the price and weigh my options :wink: suby steve also ran the same rad as i do :mrgreen:
lets just ride
PostPosted: Fri Jan 14, 2011 3:44 pm
I run the jeep radiator on the s/c ecotec and have never had any problems. You can pick a used one up on eBay cheap I got 2 for like 20 bucks. But it is the one out of a 4.0 which is dual core.
PostPosted: Sat Jan 15, 2011 4:42 pm
Well went and picked up car. I got it in my shop raised hood and thought that motor does not look like the pics on here. Called work to run vin. It was a 2.4 2001 model. Called the girl I bought it from, and told her it was not the year she had advertised. Loaded it back on the trailer brought it back, and got my money. Back to looking for a donor.
PostPosted: Sun Jan 16, 2011 12:43 pm
sorry man that sucks i ordered my motor from a junkyard they said it was a 04 i got it and its a 05 and they changed alot of stuff from 04 to 05
