It is currently Sun May 03, 2026 11:03 am
PostPosted: Fri Jan 07, 2011 10:04 pm
Do you think it would be worth it? I was thinking bout pulling suby to put busa in. I was thinkin light weight and one awsome sound at 12,000 rpm.
Somthing like this.... but in a woodsbuggy
http://www.youtube.com/watch?v=qoGGNuk6 ... re=related
PostPosted: Fri Jan 07, 2011 10:23 pm
DO IT!
PostPosted: Fri Jan 07, 2011 10:42 pm
i dont see why it wouldnt work :idea: it would be cool as hell and like you said, sound cool at 12,000 :wink:
lets just ride
PostPosted: Fri Jan 07, 2011 10:43 pm
I need a gearbox with reverse to go to the cvs. I just might try it.
PostPosted: Fri Jan 07, 2011 10:52 pm
id like to see you do it :D and would pay close attention to the build :wink:
lets just ride
PostPosted: Sat Jan 08, 2011 1:55 am
I think that any low end torque would be lacking.
PostPosted: Sat Jan 08, 2011 2:06 am
here look at this.
http://kansascity.craigslist.org/rvs/2097151967.html
PostPosted: Sat Jan 08, 2011 2:12 am
instigator wrote:
now that is cool! id like to know how its all mated together
lets just ride
PostPosted: Sat Jan 08, 2011 7:47 am
The drive line on that type of Buggy is similar to my Pilots. It uses an RPM gearbox ($2500.00) coupled to a CVT setup off of a Snowmobile. Not really the best setup for crawling around the Woods of Wellsville in your car, its to heavy IMHO. Would be a good Woods setup in a mid size chassis less than 900#. Half way between a Pilot and and a standard size buggy. BTW the Blonde is the owners wife. He is a member of Minibuggy.net
PostPosted: Sat Jan 08, 2011 12:45 pm
I thought about a street bike engine buggy too but dont think it wouuld be ideal. The engines arent cheap. They are higher maintence. The power band isnt ideal. Theres lots of power but torques weak. Weight has to be low. The engines are ment for a light motorcycle n when you put them in a heavy buggy the engines wear out alot faster.
Would be cool but no way its better then an Ecotec! lol
PostPosted: Sun Jan 09, 2011 1:23 pm
Ive got a 2007 Yamaha R1 Engine....fuel injected!!!!!...low miles too.....$500.00 buys it!....all wiring and ecu
PostPosted: Mon Jan 10, 2011 6:29 pm
:shock:
PostPosted: Mon Jan 10, 2011 6:53 pm
i think id rather ride her around instead.
PostPosted: Sun Jan 30, 2011 11:28 pm
Ive got a freind that owns a motorcycle junk yard here in alabama. he has a 1200cc motor that was run in a dwarf car. he is wanting to put it in a buggy. I think it would be bad ass. The only problem is finding a combination with reverse.
PostPosted: Tue Feb 01, 2011 9:52 pm
This 166 inch s&s should be tourqy :D and sound damn cool in the woods :D :D
