It is currently Mon May 04, 2026 4:11 am
 Post subject: 6" and 8" wider beams
PostPosted: Fri Jan 07, 2011 5:35 pm
Well I don't know how wide a standard beam is so if you can measure your wide King pin beams and post it up that would be great. The measurement would be from side to side at the torsion/leaf spring area. outside. Thanks Dave T
PostPosted: Fri Jan 07, 2011 5:46 pm
Stock link/pin beam is 34" long, end to end.
PostPosted: Sat Jan 08, 2011 8:10 am
Thanks, I ended up with some torsion bars for the front end and I do not know what they fit. I will measure and find out. Thanks Dave T
PostPosted: Sat Jan 08, 2011 12:00 pm
Link pin springs will be 3/4" wide. The ball joint springs will form a cross of sorts when looking at the profile, different sizes on width.
PostPosted: Sun Jan 09, 2011 9:26 am
Thanks MadMike, check the pic. This is what I have. Thanks Dave T Image , Image. They measure 42.25 and 45 long They are for the wider beams, just didn't know how wide.
PostPosted: Sun Jan 09, 2011 10:18 am
That's different, never seen round front torsion springs like that before. I no longer have any front torsion springs to measure for you. Perhaps someone else can chime in.
PostPosted: Sun Jan 09, 2011 2:13 pm
those torsion bars kind of look like those ones out of an old dodge front end
