It is currently Mon May 04, 2026 1:00 pm
Board index » Blogs » Perrib's Place
 Post subject: First recovery of 2011
PostPosted: Mon Jan 03, 2011 7:24 pm
First recovery of the new year and it was a long rough ride. Joe picked me up at 5 am yesterday and we got back to my house at 3 am. Last Thurday around midnight a lifted Ford F 150 was retrieving a broken rental UTV from the trail from Box Canyon to Red Mountain Mine trail it apears to have sprung a fuel leak while backing up to the UTV and the ignited fuel trail set the UTV on fire and on a rock hill both burned to the ground. An employee and his girl friend called 911. Cell reception is real spotty out there so they were lucky and the signal fire led a Sheriff's Helicopter right to them. It is been in the 20s-50s out there. The walk out is a 10-15 mile walk over treacherous terrain. We picked the easy way in see the river crossing.
The rock crawler made it up. The bank kept giving way to the weight of Joes truck we were going to winch it up but on the other side the water had made a 70 foot depression 10 feet deep that due to the trees theToySuki could just barely get around. Now it is noon time and we are only 4 miles away. We decided to trailer the rock crawler to Highway 177 and take the Battle Az trail in at 5 pm we were right back at the water crossing. We left one trailer there and loaded the UTV on the other and decided on the shortest but roughest ride out through box Canyon. We stll had to return to 177 to get the other truck. These are pictures from the second try. Tommorow were trying for the Ford.
http://s213.photobucket.com/albums/cc28 ... t%20Truck/
PostPosted: Mon Jan 03, 2011 7:30 pm
that sounds like one long day!
lets just ride
PostPosted: Thu Jan 06, 2011 10:27 pm
This was a long one. As was the UTV on Tuesday. This time to save a couple of hours we crossed the river on the trip in and out.
John left the Toy Suki at home and brought the Jack Rabbit.
This time we used the military tires and rims.
We managed to get loaded in the daylight.
This time the recovery truck hydrolocked. We unhooked the trailer and winched over the truck pulled the plugs and then turned it around and winched over the trailer.
More pictures:
http://s213.photobucket.com/albums/cc28 ... Truck%202/
PostPosted: Thu Jan 06, 2011 11:30 pm
That JackRabbit is cool
PostPosted: Fri Jan 07, 2011 4:34 pm
WOW! Sounds like you'de be better off just leaving it there.
PostPosted: Fri Jan 07, 2011 5:08 pm
If the owner does not remove it depending where it is AZ State Trust Lands, BLM and USFS remove it for your for $15,000 and up. They consider it hazardous waste.
PostPosted: Fri Jan 07, 2011 9:34 pm
Would you imagine if they did that in wellsville? They would make a mint!
PostPosted: Wed Jan 12, 2011 10:37 pm
Yesterday I took the rail and Joe out to scout the next recovery.
This one will need to be winched up 300 plus feet.
Im hoping we can get it started and open up windshield enough to be able to use the Toyos own power to help get it back up the hill.
This was very bad for the driver, eight weeks later and he is still in the hospital. He was winching up a sand rail when the rail pulled the Toyo down the hill. The Toyo had been converted to a straight axle with front rear lockers and a double transfer case. The driver also was very experienced. I believe he thought the rail was light enough that he did not need to use a tree or other vehicle as an anchor and was sitting on the seat without a seat belt. This is a very nasty hill last two times we were there all but the two vehicles that were locked front and rear had to be winched up. Both times we were there we were anchored to a tree. Thieves stole the winch, front shocks, driver rear tire, stereo system, cb, onboard air,battery. We are going to try to open up the windshield and replace the battery, three tires and broken distributor cap to use the Toyo's power to help with winching it up the hill.
