It is currently Mon May 04, 2026 2:36 pm
PostPosted: Tue Dec 21, 2010 10:47 pm
I would like suggestions on what you guys have had good luck with ? it is a new as41 case and a used 78 crank if it matters . thanks for the imput !
jason
PostPosted: Wed Dec 22, 2010 1:01 am
I use mahle on crank,rods and cam bearings(double trust).
PostPosted: Wed Dec 22, 2010 5:56 pm
I like clevite 77- H on rod bearings & mahle on cam & crank . The H bearing is for high rpm & pressure .
PostPosted: Thu Dec 23, 2010 12:47 pm
Gotta be careful on Mahle main bearings.
They are starting to produce the #2 split main bearing w/o the internal steel backing.
You can tell by the Mahle part number.
For example the normal all standard size Mahle part number is M70105.
The new version without that (IMHO) critical steel backing is SM70105.
Note the S at the start of the part number.
You can physically feel the difference in the weight of that bearing.
It is so much lighter.
PostPosted: Thu Dec 23, 2010 1:00 pm
My buddy just brought me the part number for those rod bearings couple weeks ago . do they have those in a vw journal? or just the chevy?
PostPosted: Thu Dec 23, 2010 8:53 pm
You mite find a clevitte - p bearing in a VW . Some of the german rods & mains bearings have steel back but are hard to get. Call Drews or Davis
PostPosted: Thu Dec 23, 2010 9:15 pm
VW .010 under CB 780P
Buick .010 under CB 6010P
Checker/O'Rielly often has the Buick ones in stock.
PostPosted: Thu Dec 23, 2010 9:22 pm
Thanks Perrib.
PostPosted: Sat Dec 25, 2010 9:59 am
I have a new set of Mahle mains still in the box you can have.
Give me a call.
Steve
216-695-0733
