It is currently Mon May 04, 2026 1:36 pm
 Post subject: Shifter locks up
PostPosted: Fri Dec 03, 2010 12:03 pm
I have a stock swingaxle transaxle on my buggy and if i let it sit for about a month the shifter basically locks up and is hell to move but once i get it loose and ride it a little it shifts perfectly smooth. As long as i drive it every week or so it does fine but i was wondering if it is the bushings in the nose cone causing this problem. Ive had a few buggies before and never had this problem before??
 Post subject: Re: Shifter locks up
PostPosted: Fri Dec 03, 2010 12:59 pm
Has your trans ever been sunk in a creek and the oil floated out of the vent hole and replaced with some water?Just a guess.Just enough water to make it sweaty inside.Got a trans from a huricane Mobile Al junk yard that was gaulded up this way.
PostPosted: Fri Dec 03, 2010 6:44 pm
Water infiltration is usually the cause.
PostPosted: Sat Dec 04, 2010 3:17 pm
thanks fellas...i was just wondering what i could do...
PostPosted: Sat Dec 04, 2010 4:11 pm
Drain the trans and try new oil.
PostPosted: Sat Dec 04, 2010 7:16 pm
drive it once or more time's a week!!!!! thats a good reason to get out and play!!
if your scared go to church.
drunk on diesel.. puking up soot
Bad decisions make good stories.
PostPosted: Sun Dec 05, 2010 3:16 am
:mrgreen:
lets just ride
PostPosted: Sun Dec 12, 2010 11:29 am
I tried draining the oil and putting fresh oil in last spring and the old oil was black and didnt look like it had any water in it. I have never taken the nose cone off where the shifter has bushings that i understand dont ever see any oil. Has anyone ever changed those bushings and if i pull it off are there alot of moving parts in the nose cone i need to look out for?
PostPosted: Sun Dec 12, 2010 3:52 pm
all the moving parts do get oil,theres 1 brass bushing in nose cone but dont think it will cause ur problem,,,drain ur oil and look at it 1st,try puttin a gallon of cheap motor oil in it and running it for a day or so to see if it helps
