It is currently Mon May 04, 2026 1:17 pm
PostPosted: Wed Nov 24, 2010 10:18 pm
wondering if the front spindles press out or need to be cut out making a set of drop spindles and trying to get the spindles out can they be pressed out if so thats what ill do if not ill start cutting up this weekend to get them out thanks
PostPosted: Thu Nov 25, 2010 12:49 am
we cut some with a big automatic band saw. and a buddy took some and milled them down and left a stub on the end to press into the plate then weld thats probably the best way and he just cut the the stub off spindal and left where the seal rides and put a whole in the plate the same size put it on and weld crap out of it :mrgreen: hope this helps.
PostPosted: Thu Nov 25, 2010 12:22 pm
yes thanks thats how i had planned on doing it thanks dave
