It is currently Mon May 04, 2026 8:03 am
PostPosted: Sat Nov 20, 2010 1:06 am
i was cleaning up some used intakes i have and was matching them up afterward when i noticed some had "A" and some had "B" stamped on the side while others had no markings at all :? :?:
PostPosted: Sat Nov 20, 2010 9:36 am
I suspect the A and B desinate the Offset from the left and right manifold. Easy way for the plant packers to get one of each in the box.
PostPosted: Sat Nov 20, 2010 5:07 pm
so will they not work on either side, they look the same laying side by side :?
which is right and which is left :?:
PostPosted: Sat Nov 20, 2010 6:22 pm
I think there were two sets offered. One with an offset to compensate for the 1/3 - 2/4 cylinder banks not being in line and the other set with no offset.
PostPosted: Tue Dec 07, 2010 6:24 am
so does this mean a = offset and b = straight or vice versa
or maybe its a = driver side and b = passenger side or vice versa
PostPosted: Wed Dec 08, 2010 12:43 am
Do they look ported ? If so the heads they were on were also marked a/b to keep them in the correct location.
PostPosted: Wed Dec 08, 2010 12:46 am
most definantly been ported and a souple of sets even been welded on but i dont have the heads :roll:
