It is currently Mon May 04, 2026 12:57 pm
PostPosted: Thu Nov 11, 2010 12:10 am
im lookin to buy a good vw bus engine in ky or close to it`
Brandon
PostPosted: Thu Nov 11, 2010 1:02 pm
Talk to Larry's at the speed shop. He will probably let one go cheap. 856-882-0093 :)
Life is not about reaching the grave in a well perserved body but rather to slide in sideways yelling "HOLY S@#: what a ride"!
PostPosted: Thu Nov 11, 2010 2:10 pm
Older bus engine like a Beetle engine or newer bus engine like a pancake style engine?
PostPosted: Thu Nov 11, 2010 3:29 pm
older i guess, its goin in a buggy
Brandon
PostPosted: Thu Nov 11, 2010 5:20 pm
FYI, a VW bus had a Beetle style engine in it through 1971.
PostPosted: Thu Nov 11, 2010 6:00 pm
was it a 1600cc too?
Brandon
PostPosted: Thu Nov 11, 2010 6:57 pm
What size are you looking for? Type 1 or type 4? Stock or bored and stroked? Upright or pancake?
PostPosted: Thu Nov 11, 2010 7:20 pm
Yeah, earlier versions were single ports.
PostPosted: Thu Nov 11, 2010 9:57 pm
the size dont matter to much, just the price :wink:
Brandon
PostPosted: Fri Nov 12, 2010 9:23 am
Stock type 4 motors are often very cheap....I had a friend give me 2 of them not too long ago. There are some issues with the stock type 4 motors that get expensive quick if you choose to address them. The main issues are carburetors, upright cooling, and exhaust. I run a type 4 and can discuss them with you or answer any questions you might have. I have two 2666, a 2500, and a 2800 (but only one of them is running right now).
If you are wanting an early bus motor, I'd recommend against that. As mentioned earlier, they are basically the same as a type 1 beetle motor but have most often been abused and forced to push around a heavy bus for its entire life. This makes it a poor choice for a motor to build and most would be completely worn out.
