It is currently Mon May 04, 2026 2:02 pm
 Post subject: Cleaning Diamond Plate?
PostPosted: Sat Nov 17, 2007 5:35 pm
So, what do you guys use to clean Diamond Plate Aluminum to make it shiny again? Just thought I would see what you guys think works the best before I buy anything. thanks in advance, Donnie
PostPosted: Sat Nov 17, 2007 7:48 pm
Have used the POWERBALL by Mothers. Works ok - dont use w/ die grinder - they spin to fast. Have also used buffing wheel on 4.5 grinder and on a die grinder w/ arbor. W/ the buff wheels you can cut more oxidation off quicker with the right rougesor metal polishes.
PostPosted: Sat Nov 17, 2007 9:09 pm
A friend of mine was telling me that there is a recipie on the internent that you can mix up and use.He is a farmer and they use it to clean all their stuff.I'll try to find more info and post it.
