It is currently Tue May 05, 2026 7:20 am
 Post subject: WTB parts
PostPosted: Wed Aug 18, 2010 3:43 am
i am looking to buy a set of 2x3 trailing arm with bus stub axles or just either of the two seprate i am need a possibly needing a bell housing to bolt up to a six rib and a subaru motor my brother volksdude07 said that there is such a thing im not sure where i could find one or if some one has one for sale for a reasonable price any input on that or selling anything or could possibly trade vw parts for them?
*subiepower*
 Post subject: Re: WTB parts
PostPosted: Wed Aug 18, 2010 7:27 am
Check out Bigscotts build he got one,
http://www.woodsbuggy.com/index.php?opt ... 47&start=0
PostPosted: Wed Aug 18, 2010 7:35 am
Heres one on ebay, probly the way Id go
http://cgi.ebay.com/ebaymotors/Subaru-V ... ccessories
PostPosted: Wed Aug 18, 2010 5:22 pm
make sure you buy there pressure plate because some of the stock one are not compatitable. save your self the headach if your going that way. :oops:
PostPosted: Wed Aug 18, 2010 6:00 pm
sawyer! makes very nice 2x3 trailing arm's!!!
if your scared go to church.
drunk on diesel.. puking up soot
Bad decisions make good stories.
PostPosted: Wed Aug 18, 2010 6:08 pm
it works with the stock 2.2 or 2.5 clutch not the wrx clutch. The wrx clutch is a pull release and the other is push
PostPosted: Wed Aug 18, 2010 9:38 pm
you have to measure the center hole of pressure plate. we had this problem with the one we did and it took a few rides befor it tore it up. this is the email that i got after i sent pics to him.
"The release bearing slipped through the pressure plate fingers causing it to over travel. This happen because center between the fingers is too wide in diameter. If you compare the Valeo pressure to OEM, the OEM center is smaller in diameter. "
Best regards,
Mao
Online Sales Manager
Small Car Performance
4720 South Tacoma Way
Tacoma , WA 98409
PostPosted: Thu Aug 19, 2010 12:27 am
ok i see how it goes thx alot that gives me some options i got all winter to make this right and dont wanna have to do things a secound time now this might be a stupid question but with that bell housing for the bus tranny to the subaru can you use the stock hydralic pedal off a subaru on it or what kind of clutch would work?
*subiepower*
