It is currently Mon May 04, 2026 3:05 pm
 Post subject: good setup?
PostPosted: Thu Aug 12, 2010 5:46 pm
Do u think this is a good setup, stock 1600 case with 1641 pistons and juggs stock heads with scat rockers and a webber progressive carb
if you cant duck it fudge it
 Post subject: Re: good setup?
PostPosted: Thu Aug 12, 2010 8:03 pm
If it is built well, it should run for a long time.
PostPosted: Fri Aug 13, 2010 1:03 pm
I think u hook. It to a 3 rib and only have 12" wide tires u can do just about anything with it
PostPosted: Fri Aug 13, 2010 5:24 pm
If the rockers are 1.25 put high rev springs on the heads & a w100 cam
PostPosted: Fri Aug 13, 2010 7:22 pm
Well i unfortionatlly have a car tranny with a swing axel can get a 3 rib from my buddy for cheeeeap but then have tp convert it to irs n cant afford new traling arms etc
PostPosted: Fri Aug 13, 2010 7:23 pm
And they are 1.25 rockers
PostPosted: Fri Aug 13, 2010 11:35 pm
If they are just stock rockers on Scat solid shafts go for a VZ 14 cam. x2 on the 100 with 1.25 rockers. There were stock looking 1.25 rockers. The hole for the pushrod is off set for the 1.25 ratio and centered for the 1.1 ratio. With 1.4 rockers get the FK 65 cam. Use single HD valve springs and retainers.
PostPosted: Sat Aug 14, 2010 12:04 pm
Hyde I see where your going with that.I built a motor with a Ingle100 it was a torx monster
PostPosted: Thu Aug 19, 2010 7:00 pm
1641 with a swingaxle was in my first buggy back 20 years ago. I ran the hell out of that buggy and had a blast with it. Run it and have fun! :mrgreen:
Roy
