It is currently Mon May 04, 2026 11:00 pm
 Post subject: Help with front end?
PostPosted: Thu Aug 05, 2010 1:50 pm
So right now i have my front end set up for ball joint with a torsion bar. Is there any way to make the torsion bar (inactive) or is there something i can get so i can still use what i already have? I would like to do this because i want to run coil overs instead of torsion bars.
 Post subject: Re: Help with front end?
PostPosted: Thu Aug 05, 2010 2:11 pm
I believe what the guys are doing is removing the torsion and replacing it woth a threaded rod.
PostPosted: Thu Aug 05, 2010 3:01 pm
If you remove the torsions then you will need air shocks or coil overs to replace them. Something has to hold the Buggy up.
PostPosted: Thu Aug 05, 2010 3:24 pm
Last sentence says he wants coilovers
PostPosted: Thu Aug 05, 2010 3:56 pm
Well it would appear I had another senoir moment! They are getting more frequent lol :roll: :mrgreen:
PostPosted: Thu Aug 05, 2010 4:27 pm
I'm in my mid 30's and have them daily :mrgreen:
PostPosted: Fri Aug 06, 2010 7:29 pm
So i would be able to use the threaded rod with what i have now?
PostPosted: Fri Aug 06, 2010 7:33 pm
yep
PostPosted: Fri Aug 06, 2010 7:51 pm
Alright thanks guys.
PostPosted: Sat Aug 07, 2010 2:47 pm
i would reinforce the ends of the arms, were the rods would come through. the little end caps are really thin.
