It is currently Tue May 05, 2026 10:30 am
Post new topic Reply to topic  [ 173 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 7  Next
PostPosted: Sun May 09, 2010 11:34 am
I wanted to do that to my tank too, but I dont have a welder for aluminum. awsome buggy! How do ya like the bellhousing adaptor?
PostPosted: Wed May 12, 2010 9:04 pm
I like the design and being able to use the subaru clutch setup! But I guess I won't know how much I like it intil I get to drive it! :lol:
I got the engine and tranny mounts made and tacked in.
PostPosted: Thu May 13, 2010 10:28 am
You are gonna have to change your user ID to SubyScott........... :mrgreen:
Lookin' good there Scott.
PostPosted: Mon May 24, 2010 12:11 am
Got the gas tank mounts done today.
PostPosted: Mon May 24, 2010 12:15 am
looks great scott!!!
lets just ride
PostPosted: Tue Jun 08, 2010 9:29 pm
Ok, I got the seats, shifter, tilt wheel, power steering ram and wheels mounted.
PostPosted: Mon Jun 28, 2010 10:22 pm
anymore progress :?: i love this thing :D
PostPosted: Tue Jul 27, 2010 4:00 am
I finally got to work on the buggy tonight, i've been working out of town so much that i haven't got to get anything done. I got the steering ram mounted and the rack modified.
PostPosted: Tue Jul 27, 2010 10:04 am
Where did you get the u-joint driveshafts from?
PostPosted: Tue Jul 27, 2010 6:03 pm
Here is the link http://www.sandstuff.com/
I will say I have never used them before and I have heard good and bad about them. It does seem that the people who have had trouble are running high output engines like a turbo Ls1. If you goto glamis dunes forum at http://www.glamisdunes.com/invision/ind ... owforum=72 you can do a search on them and read what people have to say.
PostPosted: Tue Jul 27, 2010 8:03 pm
Looking good Scott
PostPosted: Tue Jul 27, 2010 9:26 pm
Here is an old woodsbuggy post on CV verse U-Joints. Some good info on both sides
http://www.woodsbuggy.com/index.php?option=com_jfusion&Itemid=10&jfile=viewtopic.php&f=4&t=6819&st=0&sk=t&sd=a&hilit=u+joint
PostPosted: Sat Oct 02, 2010 5:51 pm
Here is a pic of the internal stop for the steering ram
PostPosted: Sat Oct 02, 2010 6:14 pm
very very nice scott! i talk to randy alot on the phone, look forward to meeting u both at d@k
lets just ride
PostPosted: Sat Oct 02, 2010 7:41 pm
Thanks, I had hoped to have had this buggy done already. :roll: But you know how that goes! I look forward to meeting you and a bunch of other guys off this site.
PostPosted: Sat Oct 02, 2010 10:25 pm
what are your springs in the front? i have the same shocks and trying to firgure out which ones to get...i have way to stiff ones right now i think...and you got coils in the rear right?....what size stroke...?
give me a call...910-520-2126
PostPosted: Sat Oct 02, 2010 10:33 pm
yes i sure do! my conversion should have took a month and four months later im ready to ride :wink: :wink:
lets just ride
PostPosted: Sun Oct 03, 2010 3:51 pm
Got the floor tabs welded in and the floor bolted up.
PostPosted: Wed Oct 06, 2010 8:13 pm
First i like the looks of that buggy. But my concern is no cross bracing in that cage or maybe i can't see it. But if it's not there and you were to roll it over you have got to have that. jus my .02
PostPosted: Wed Oct 06, 2010 9:50 pm
I'll 2nd that. X-Bracing is definitely a must!
-Dakotah/koko
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Wed Oct 06, 2010 11:02 pm
-Dakotah/koko[/quote]
[quote="kyjr.buggy1"]I'll 2nd that. X-Bracing is definitely a must!
Thanks. Its not installed yet, but it is for sure getting it!
PostPosted: Thu Oct 07, 2010 7:41 am
Also, bracing in your roof itself adds alot of strength, too. Similar to your bracing on the front end. A brace in the center going across horizontally out of 1.25" pipe, then make an "X" out of 1". It should tie in at each corner of the roof. That would help ALOT, especially with the flat roof. 8)
-Dakotah/koko
-Dakotah/koko
PostPosted: Thu Oct 07, 2010 2:41 pm
Interesting, When I spoke with the owner Howe he never mentioned anything about Installing an Internal stop. Only to make sure that the Ram stopped in the same place as the Rack on each end.
PostPosted: Thu Oct 07, 2010 9:08 pm
Not sure who I talked to there, I just called their number and said I had some tech questions. The guy told me the ram would destroy the rack if all I used were the built in stops of the rack. He told me how to take it apart and what size material to use to build the internal stop.
PostPosted: Tue Nov 02, 2010 10:31 pm
Got my adapters back from the powder coater this week, I wanted to make sure that I liked the blue I have picked out for the frame.
cron
