It is currently Tue May 05, 2026 10:30 am
PostPosted: Tue Jul 27, 2010 2:47 pm
Hey guys... I am putting together a 1915 and have a set of basically stock 042 heads that have been punched out already to 94 that I got with the motor. But I also have a set of after-market 044 heads that are still stock size off my old motor... any suggestions on which ones I should run? I will be running 90% of the time in Wellsville. Seems to me like I should go for the highest compression with the low end torque... I am not sure of the valve size on either set. Should I run with the 042 and have valve work done or would I be better off to have my after-market heads off my old motor punched out? I am new to these things and any input would be appreciated.
PostPosted: Tue Jul 27, 2010 3:34 pm
Its MUCH cheaper to buy new heads with bigger valves than to have them installed on old heads
PostPosted: Tue Jul 27, 2010 3:50 pm
personaly, the 042 heads would be the best for the 1915 in my opinion. the valve sizes are 42intake and 35.5 exhaust. i run the same size heads on my 2275 and i love them. the engine has plenty of bottome end. but i think your cam selection will be the biggest factor. what size cam are you gonna run?
PostPosted: Tue Jul 27, 2010 4:02 pm
its simple really the bigger the heads the better it runs
PostPosted: Wed Jul 28, 2010 3:34 pm
DEPENDS ON HOW U WANT TO RIDE YOUR BUGGY.
PostPosted: Fri Jul 30, 2010 4:35 am
i run 042 heads and a engle 110 cam on my 1915 and it is an awesome setup
cron
