It is currently Tue May 05, 2026 9:12 am
 Post subject: Spark arrestor???
PostPosted: Wed Jul 14, 2010 3:12 pm
I need one for at the dunes, any ideas????
Here is a pic of the exhaust.
 Post subject: Re: Spark arrestor???
PostPosted: Wed Jul 14, 2010 5:19 pm
What size is that pipe before the weld?
You gotta have something like this:
Here is that section of the website.
http://www.supertrapp.com/product_secti ... p?CatID=32
PostPosted: Wed Jul 14, 2010 5:27 pm
make up a sleeve that will fit in your exhaust or on the outside that you can bolt on. then take the plates from a supertrapp exhaust pipe and weld them on to the sleeve.
PostPosted: Wed Jul 14, 2010 6:40 pm
Called Appletree, I think we have something worked out.
PostPosted: Wed Jul 14, 2010 8:21 pm
It woud be cheaper to got to advance auto and get their shorty Thrush $15 muffler.
PostPosted: Wed Jul 14, 2010 9:10 pm
Not changing mufflers, just adding the plates that got lost. This was a sandrail when I bought it, so it was set up for it already.
PostPosted: Fri Jul 16, 2010 2:03 am
Just add a turbo! that will pass as a spark arrestor ! :mrgreen:
PostPosted: Fri Jul 16, 2010 8:25 am
I'm with you Mudd mutt. I'd turbo my lawn mower if I could cut grass that fast
PostPosted: Fri Jul 16, 2010 10:02 am
Id rather add a SC, but not sure it would help, lol.
PostPosted: Fri Jul 16, 2010 11:41 am
The Silver Lake spark arrestor rule.
Quote:
EXHAUST SYSTEM RULES AND TESTING
Vehicle muffler noise and the use of spark arresters has been a matter of concern regarding the operation of ORVs for many years. Michigan's ORV Law has required them since 1975. At Silver Lake State Park, a static or stationary test for this equipment is used on all types of vehicles. Noise levels will be checked at a 20-inch distance from the exhaust pipe at half the vehicle's rated revolutions per minute (RPM) or as detailed in the automotive specifications SAEJ1169, March 92 or SAE J1287, June 86. The maximum noise level permitted under these testing conditions will be 94 dBa which is the current limit set by the Off-Road Recreation Vehicle Act as Park 811 of 1994 PA 451 (MCL 324.811). All vehicles are required to have a muffler and spark arrester containing baffles meeting established United States Forest Service specifications.
Generally speaking, the guidelines for testing at "half the rate RPM" will be based on some vehicle similarities. In most cases, full-sized vehicles with "V" configured engines will be tested at 2,500 RPM and all others at 2,000 RPM, which was a method developed and used while testing these vehicles at Silver Lake in 1997. Diesel powered, full sized vehicles are tested at 1,500 RPM. Most reverse flow mufflers will meet the spark arrester requirements, as will most turbochargers. However, straight-through mufflers, such as glass-packed design, without baffles and mechanically driven superchargers, do not qualify as adequate spark arresters.
Motor cycles and ATVs will be tested like the full-sized vehicles by placing a sound meter at a 20-inch distance from the muffler exhaust pipe. In most cases, 80cc engines will be tested at 6,000 RPM, 125 cc at 5,000 RMP, 250 cc at 4,000 RPM and 500+ at 3,000 RPM. Annually, the Motorcycle Industry Council produces a manual detailing the standards ATVs and motorcycles must meet. A muffler that meets the Environmental Acoustic Reduction (EAR) standards may be considered as a viable solution for motorcyclists. Many ATV and motorcycle mufflers are stamped as being USFS approved and will meet the Silver Lake State Park standards, if they have not been altered. Those vehicles that have been manufactured for "closed track" use only, such as many motorcross or dirt bike motorcycles and competition style ATVs, will most likely not meet the requirements. This is also often true where after market installations have altered the original exhaust system in attempts to gain additional horsepower.
Testing for compliance with these regulations will be done in a random fashion either within the ORV Area Parking Lot, at the base of the ORV Area entrance ramp roadway by the Safety Check Station or within the ORV Area sand dune complex itself. Park Rangers and other Law Enforcement Officials may insert a plastic rod into the vehicle's exhaust pipe to determine whether there is a spark arrester or baffle present. Most often home-made baffling devices, such as steel wool or metal screen door material, do not meet the USFS requirements.
This excerpt was taken from the State of Michigan DNR site. Please visit the DNR site for more information: http://michigan.gov/dnr/0,1607,7-153-10 ... --,00.html
cron
