It is currently Mon May 04, 2026 10:50 am
 Post subject: rancho shocks
PostPosted: Thu Jul 01, 2010 11:29 pm
has anyone on here used the rancho 5000 shocks?
Brandon
 Post subject: Re: rancho shocks
PostPosted: Fri Jul 02, 2010 3:03 am
I think I priced some long travel ones once, but they were expensive and did n't know of any one using them. What sort of suspension do you have? That will depend what type of shock you need as well as how and where ,(terrain) you drive, and the buggies wieght. I got mine from FOA- (First over all), built in Nevada and custom valved for my buggies wieght. I "E" mailed them, told them I was building a woods buggy, described my suspension and the buggies use. They recomended the valving and spring rates. Cheaper than Fox or King and pretuned for the vehicle. I'm using coil overs all around, duals in the rear. They also build/ sell bump stops, air shocks and by-pass shocks also for less than the name brands.
PostPosted: Fri Jul 02, 2010 6:56 am
its bout 50/50 high way and the strip jobs i got a set of monroes last year and i it apart from my trailin arm when i had to put my bushings in and they are already wore out so im just tryin to find some good ones without breakin the bank
Brandon
PostPosted: Thu Jul 08, 2010 11:03 am
I've got the rancho 5000's on my buggy. They seem to do a good job so far. I think I gave 52 each for them from o'reillys. I've got the part number at the shop of the ones I got if you want it?
PostPosted: Thu Jul 08, 2010 11:55 am
If I was to go with The Racho's it would be the 9000 series. They have compression adjusters on them to fine tune your buggy ride. IMHO there worth the extra Bucks.
PostPosted: Sun Aug 29, 2010 2:40 pm
Do they make a 9009 shock i think i seen a set on a buggy?
