It is currently Sun May 03, 2026 4:30 pm
 Post subject: Starter problems
PostPosted: Fri Jun 25, 2010 10:36 pm
Recently installed a 2332 on my buggy with a 6 rib trans. Have a stock 6 rib starter on it and it seems like if the motor catches the gas immediately it cranks over fine. But if it doesn't, it can barely move the motor when the compression hits. The motor is set at 10.5 to 1. Trans is a 091 if that matters. Do yall think the starter is just going bad or am I on the line to having to go to a high torque starter?
