It is currently Mon May 04, 2026 1:36 pm
 Post subject: oil pressure question
PostPosted: Wed Jun 16, 2010 5:50 pm
how much oil pressure do you guys usually have at idle..? with a h.d shadeck oil pump and 15w40 oil i have about 20 psi at idle...does that sound right? seems a little low to me
PostPosted: Wed Jun 16, 2010 7:48 pm
is that hot? how much does it go up when you throttle it? i think i heard that it should climb like 10lb for every 1000 rpm. i may be wrong :roll: if i am someone please correct me. :mrgreen:
PostPosted: Wed Jun 16, 2010 10:42 pm
20 lb at idle sounds good to me as long as its hot
PostPosted: Thu Jun 17, 2010 8:42 am
That is fine, my new engine used to idle at 6-8 psi hot until I put on a Bugpack 2-stage pump and a killer oil cooler with a fan and now idles at 30 psi on a hot day.
PostPosted: Fri Jun 18, 2010 4:41 pm
20 psi. is fine if the engine is hot.
