It is currently Sun May 03, 2026 4:30 pm
PostPosted: Mon Jun 07, 2010 10:15 pm
I have 33x10.50 boggers, they hook good (well fling alot of s@#$). Will I sacrifice my axles, cv, tranny to take the small lugs off? I'm not a primary hill climber, lets face it I have a non stroker 4 seater with heavy (but nice) coilovers. The more traction the better but I don't want to replace parts every weekend.
PostPosted: Tue Jun 08, 2010 8:41 am
I have not run uncut Boggers so I have no empircal data to pull from. However they are a very stiff tire and do not flex with out at least cutting some meat off between the lugs and sidewalls. I will also say that they are a very heavy tire and removeing the little lugs and additional meat will make them lighter and less burdon on the drive train and of cource give you a lot better performance. Every pound you are rotating equates to 50 pounds of spinning mass. If your happy with the way they perform then leave them alone.
PostPosted: Tue Jun 08, 2010 11:57 am
Cut 'em and let er eat!! I broke plenty of stuff without cutting them so dont fool yourself into thinking it really make a difference on how safe your trans is. :wink:
PostPosted: Tue Jun 08, 2010 6:53 pm
CUT & cut :twisted:
PostPosted: Tue Jun 08, 2010 7:25 pm
Cutting tires
Pro's and cons.
Pro's
1 Less weight means less stress on Drive train
2 Less weight means less strain on your engine
3 Cut tires will flex and get better traction
4 Cutting small lugs off will remove weight and make larger cleanouts for better traction.
Con's
1 Cut boggers will not be street legal.
2 Small lugs cut off will increase the chance of ripping off a large lug.
3 ?????? ok I don't have a third.
PostPosted: Tue Jun 08, 2010 9:38 pm
I had a feeling thats the response I was going to get... I might do a little trimming, Its hard to cut up new tires. I think I was always going to cut them but I needed a little peir pressure/support :D
PostPosted: Tue Jun 08, 2010 10:04 pm
I have never known anybody that cut their tires and said they wish they hadn't ! SO GET AFTER IT !!!
PostPosted: Tue Jun 08, 2010 10:10 pm
I disagree, not because of the tires. Because of the work and knotted up forearm, lol.
PostPosted: Wed Jun 09, 2010 8:57 am
I guess you will have to lift some more weights! :roll: :wink:
PostPosted: Wed Jun 09, 2010 9:55 am
Haha, very funny. I just have KOKO cut them :mrgreen:
PostPosted: Wed Jun 09, 2010 1:27 pm
stanley 1 inch .25 clear handle wood chisel works very easy. Needs to be on rim with air in it.
PostPosted: Wed Jun 09, 2010 11:24 pm
I don't think koko wants to cut anymore boggers after he cut firebugs.
PostPosted: Mon Jun 21, 2010 6:53 pm
nitro_mudder wrote:
Cutting tires
Pro's and cons.
Con's
i have ran cut boggers on the street and been pulled over for speeding in a jeep and the only thing the cop asked was if they were DOT approved he saw it on the sidewall and i went about my way.. and they were on 32 bolt beadlocks "told him they were fake locks lol"
