It is currently Sun May 03, 2026 6:19 pm
 Post subject: How to put a lug back on
PostPosted: Sat Jun 05, 2010 4:13 pm
What's the chance that Gorilla glue will hold a lug on?
PostPosted: Sat Jun 05, 2010 7:32 pm
how did that happen
PostPosted: Sat Jun 05, 2010 7:34 pm
showin out at Choccolocco Mountain :oops:
PostPosted: Sat Jun 05, 2010 9:46 pm
Haha, I'm missing a few half lugs after wellsville. I don't think it will work but if it does you should get paid for advertising.
PostPosted: Sat Jun 05, 2010 11:03 pm
send it to David Hill he can sew them back on :shock:
PostPosted: Sat Jun 05, 2010 11:44 pm
Bolt it back on .. :D :D
PostPosted: Sun Jun 06, 2010 12:10 am
Run some carriage bolts thru it , from outside in.
PostPosted: Sun Jun 06, 2010 5:42 pm
try some vulcanizing compound...
PostPosted: Sun Jun 06, 2010 6:16 pm
purplerail wrote:
how did that happen
Not enough radius at the bottom of the lug.
Good for grip, but not for strength :D
The gorilla glue is fairly strong and flexible, but for rubber you'll really need to prep it with 80-120 grit sandpaper and scrub it with acetone, a primer for low surface energy materials would help too.
Id've put some serious weight on the lug to make sure the bond line was nice and thin too!
PostPosted: Sun Jun 06, 2010 7:26 pm
Ive got some stuff you can try if it doesnt work. Pm me if your interested...
PostPosted: Sun Jun 06, 2010 10:50 pm
I sent it off to be vulcanized and it came back,. they said not enough material left to work with.
PostPosted: Sun Jun 06, 2010 11:48 pm
Take some pictures of the lug seperated from the tire. You may have to bolt it for rigidity but my stuff should seal it up. I sell this stuff for a living and I have a few "samples" I can give you to try....
PostPosted: Mon Jun 07, 2010 7:30 am
If it brakes off again I will try your stuff. Koko is my hero,,,he cut them just as I requested. The hill I climbed would have torn off lugs off an uncut bogger. These tires do very well but only thanks to the superior cutting job. They are cut for fresh cut hills with some soil,,not rock gardens. A good set of Irocks would be more suitable for that rock crawler hill at Chocco.
PostPosted: Mon Jun 07, 2010 9:15 am
But then he will have to borrow tires for the hill climbs :mrgreen: Just ask Bruce about that, lol.
