It is currently Mon May 04, 2026 12:38 pm
 Post subject: Help! Bogger Size
PostPosted: Sun May 23, 2010 10:12 pm
I need to order some tires this week. But I need some help figuring out what will fit my buggy. I need to know what the overall height of a 35 x 14.00 x 15 bogger on a 15 x 14 wheel would measure? Can anyone help me out with this measurement?
TIA,
Caleb
 Post subject: Re: Help! Bogger Size
PostPosted: Sun May 23, 2010 11:16 pm
i dont have any myself,but from what i read the guys on here that run 35s say they measure 32.5 to 33 inches tall.. maybe that helps
lets just ride
PostPosted: Sun May 23, 2010 11:29 pm
You may not be able to let tire presure down as low as you would like with 14wide , may need 12 wide in my opinion.
PostPosted: Mon May 24, 2010 12:27 am
My 35x14.50x15 boggers on duralite beadlocks are 32.5 tall and I run them with 2psi of air with no problems yet. I also run tubes.
I will let you know tomorrow how tall 35x16x15 boggers on a 14" beadlock is.
PostPosted: Mon May 24, 2010 12:45 am
Thanks guys. Im trying to clear the stock torsion tubes but still put the tallest tire on it possible. It has 31 x 15.50 vtreads on it now with about an 1.5" of clearance...
PostPosted: Mon May 24, 2010 12:59 am
what trailng arms u using?
not sure with stock arms but 3x3 arms will clear 38.5 boggers ona buddof of mines buggy but i got 35x14.50 bogger on 10 in. wheels and have plenty of clearance, but i got 3x3 arms also
PostPosted: Mon May 24, 2010 1:01 am
Im on stock boxed arms. they measure roughly 21". Im thinking about goign with 3 x 3 but I wan tto ride memorial day weekend so I dont know if I have enough time to get them here and installed with my work schedule....
PostPosted: Tue May 25, 2010 1:01 am
35's wont fit with stock arms need atleast 2x3's
PostPosted: Tue May 25, 2010 9:41 am
35x16x15 on 14" beadlocks are 33-1/2" tall
PostPosted: Tue May 25, 2010 10:47 pm
How low of air pressure can you run with that set up??hillaholic thanks
PostPosted: Wed May 26, 2010 9:48 am
I run 2psi in mine with beadlocks and tubes. Only reason I run tubes is because the wheel is so wide I didn’t want the inner bead popping off. I haven’t checked the air in them in 4-5 months and they are still holding the buggy up, and if you haven’t seen them the sidewalls are cut to the cords for more flex.
PostPosted: Wed May 26, 2010 3:55 pm
I like the ( i cant drive 55 sign on skidpan) .I knew on mine ,I couldnt run to low inside bead would break down. but no tubes in mine. thanks.
PostPosted: Sat May 07, 2011 9:48 am
what size rear arms are you running
PostPosted: Sat May 07, 2011 11:03 am
3x3's
