It is currently Mon May 04, 2026 11:39 pm
 Post subject: 930 cv problem
PostPosted: Wed May 12, 2010 8:06 pm
Got a 930 cv that is stuck in the stub axle. I have the inner race and balls out to work on it, but no luck. any ideas?
 Post subject: Re: 930 cv problem
PostPosted: Wed May 12, 2010 8:15 pm
Can't believe I'm saying this.............Get a bigger hammer. And maybe a block of wood, it's hammer time.
PostPosted: Wed May 12, 2010 8:34 pm
Not sure I wanna admit what I had to do to get it off, lol. But it worked.
PostPosted: Wed May 12, 2010 9:17 pm
At least it didn't come out without thinking about it.
I had some latest rage 930 stubs that had to get machined down a touch so the cv didn't get stuck. Sounds like the case.
PostPosted: Wed May 12, 2010 9:30 pm
Might be the problem, got stuck last year too. Maybe after I grind the welds down it will slide in and out easier :shock:
PostPosted: Wed May 12, 2010 9:39 pm
Welds on what?
PostPosted: Wed May 12, 2010 9:52 pm
MadMike wrote:
Welds on what?
Ummmmmm, oh nothing, don't worry about it :roll:
PostPosted: Wed May 12, 2010 10:13 pm
hell, my first buggy had the spring plates welded to the trailing arm. (not by me)
You know, If you weld it you don't have to worry about the bolts coming loose. :shock:
PostPosted: Thu May 13, 2010 2:27 am
nitro_mudder wrote:
MadMike wrote:
Welds on what?
Give it, Nitro. We all want a good chuckle.....what did you have to do to get the outer off the stub?? :lol:
PostPosted: Thu May 13, 2010 7:43 am
Had to weld 2 tabs on it so I could use my gear puller on it. Still didn't come off easy.
PostPosted: Thu May 13, 2010 7:54 am
:shock:
DAmn!
I've had to thump 'em pretty good with a hammer from time to time, but nothing like that.
Waterpumper leak on it n make it rust in place? :P :mrgreen: j/k, glad it worked out. 8)
PostPosted: Thu May 13, 2010 8:21 am
kybuggy1 wrote:
:shock:
DAmn!
I think it was a rust issue. Thought I put anti-sieze on it last yr. Must not have.
