It is currently Mon May 04, 2026 10:55 pm
 Post subject: msd cap
PostPosted: Sat May 01, 2010 10:58 am
Does anyone know the replacement cap and button for msd ignition from Autozone or Advance? I know it is Chevy,but not sure what make and year.
 Post subject: Re: msd cap
PostPosted: Sat May 01, 2010 11:21 am
not sure on cap but rotor button is 1973 chevy camaro Z28 5.7
PostPosted: Sat May 01, 2010 5:23 pm
the cap is a ford tempo and a gm v8 points rotor
PostPosted: Sun May 02, 2010 1:29 am
Mike,,IMO your going to have trouble(spark ark,moisture) with the az crap! stick with og MSD
PostPosted: Sun May 02, 2010 9:01 am
I have and MSD cap if you want it. Its used however in really good shape. You can have it if you want to come and get it. You gonna be in the Chardon or Cleveland area any time sone.
PostPosted: Sun May 02, 2010 8:47 pm
Thats would be the best way to go,but Drews never had any and i didn't want to wait to order one.Mine is all rusted up again from setting all winter.My hole distributer is also rusted up.Was going to start with new button and cap then clean dist. and try to seal it up better this time.
PostPosted: Sun May 02, 2010 8:50 pm
Thanks for the offer but i live in sw ohio and never get up that way.
PostPosted: Sun May 02, 2010 10:11 pm
Mine did the same thing. I guess its common on MSD distributors. Look online about it, tons of people have problems with rust and MSD. I sprayed mine down with WD-40 after cleaning it and its good now.
PostPosted: Mon May 03, 2010 12:01 pm
I also heard it was 4 cylinder Ford.
Maybe 2.3 ?
PostPosted: Mon May 03, 2010 12:30 pm
I did a search on my Carquest dealer site and I think a 85-87 2.3 turbo T-Bird cap works.
They list 3 different caps so you may have to match it up at your local parts store.
All are similar to this one.
PostPosted: Thu Jan 06, 2011 3:52 am
has anybody ever got a grey msd brand cap for a msd distributor?
i ordered 2 from summit racing ( they look like the ones above except for they have brass post ) and they were in msd box's but all the other msd brand caps i have seen were red :|
the reason im asking is, i'm having trouble with the cap not fitting correctly, for some reason when you go to tighen the cap down it wants to rock up on the opposite side, and it dont matter which side you tighten first :?
the first one i tightened one side a little and then the other till it was tight and i thought it was gonna be ok, but when i went out to the shop the next day i looked and it had cracked pretty bad on both sides right above the screws while sitting overnight :roll:
PostPosted: Thu Jan 06, 2011 8:56 am
Chris im pretty sure that the cap has to go on one way mine has a square peg on one side and a round peg on the other. Maybe you'll get lucky and just turn it 180 degrees.
PostPosted: Thu Jan 06, 2011 9:05 am
Jeg's part numbers-----cap 121-8475
Rotor 121-8470
You can get them next day as long as you ordered them by 9pm the day before.
PostPosted: Thu Jan 06, 2011 3:55 pm
yeah brian i thought i might have done that on the first one, but i made sure on the second one and it done the same thing, and for some reason they keep getting these big ole green "buuggers" on the inside terminals causing it to act like its got a stopped up jet or fowled plug or something :?
PostPosted: Thu Jan 06, 2011 9:27 pm
mine is gray also chris. no problems.
