It is currently Mon May 04, 2026 8:18 am
PostPosted: Wed Apr 28, 2010 7:52 am
May sounds a silly question but I've always put the bars back in the same way and never really took much notice - but will a spring plate fit on either end of a rear torsion bar or are they handed with a different spline on the inner?
Thinking about using one to make and anti-roll bar with a spring plate on either end.
PostPosted: Wed Apr 28, 2010 8:15 am
Different number of splines on each end of bar.
PostPosted: Wed Apr 28, 2010 8:16 am
Cheers, so much for that idea then :lol:
PostPosted: Wed Apr 28, 2010 9:39 am
It's still a good idea,,,you could remove the splined section from a torsion tube and graft (weld) it into a spring plate. I have done similar by using a hole saw to remove the splined section from spring plates to graft into the short spring plates when using large tires.
PostPosted: Wed Apr 28, 2010 8:00 pm
You can buy the center spline section, can't remember where right now.
