It is currently Sun May 03, 2026 6:44 pm
 Post subject: Mounting rear shocks
PostPosted: Sat Apr 24, 2010 2:30 pm
Hi Guys
Getting ready to mount my rear shocks and need some info.
The rear mount location on frame won't work and the lower mount on the 2x3 arms won't work eather.
So I am going to use double shear type mounts .
Somewere I read that the shock should be 90 degrees from the lower arm with the arm at full upward travel.
I have seen a lot of rear shocks leaning forward.
Which is right???
Thanks
MoblMec
 Post subject: Re: Mounting rear shocks
PostPosted: Sat Apr 24, 2010 2:48 pm
as close to 90 degrees is the best that how shocks are made to work but it does not always work out like that. :roll:
PostPosted: Sat Apr 24, 2010 9:03 pm
When the arm is all the way up the shock would be leaning forward to be at 90*.
PostPosted: Sun Apr 25, 2010 12:38 am
x2
When your rear suspension is at full compression the shock will be at 90 degrees.
