It is currently Sun May 03, 2026 4:31 pm
PostPosted: Sun Apr 18, 2010 9:01 pm
IVE GONE THROW 4 IGNITERS IN A MOUNTH AND I CANT FIGURE OUT WAT IS BURNING THEM UP IVE CHANGED COILS ALL MY WIRING SWITCHS GROUNDS EVERTHING NEED SUM HELP
PostPosted: Sun Apr 18, 2010 9:13 pm
More info..is it AC, or ? Petronix? Is the wiring good and corect? sounds like a short or bad ground.
PostPosted: Sun Apr 18, 2010 9:38 pm
PostPosted: Sun Apr 18, 2010 9:40 pm
jackson.ryan29 wrote:
i dont know wat a ac or petronix is but do i need a ground from the coil to frame or body ground
PostPosted: Sun Apr 18, 2010 9:43 pm
AC = air cooled
Petronix is electronic ignition
Ground is most important.
PostPosted: Sun Apr 18, 2010 9:55 pm
AC = air cooled
Ground is most important.[/quote]
air cooled yes
and it is a electronic ignition
an it doesnt have a gound other than the one that goes to the pick up in the dis.
PostPosted: Sun Apr 18, 2010 10:18 pm
what kind of coil do you run???
PostPosted: Sun Apr 18, 2010 10:32 pm
I had a accel super stock on first two than msd blast 2 on one and now just a plain Jaine 12 volt mopar coil
PostPosted: Sun Apr 18, 2010 10:44 pm
accel and blasters dont play well with ignitors get a blue coil
PostPosted: Sun Apr 18, 2010 10:59 pm
^^^^^^^^^^^correct
and the neg. on the coil only goes to the black wire from the distributor and NOT to any other ground but it used as the signal source for a tach if you happen to have one of them
PostPosted: Mon Apr 19, 2010 6:34 am
so a blue coil would be the bosch coil
PostPosted: Mon Apr 19, 2010 8:23 am
Yep. Purple is right on with this one.
PostPosted: Mon Apr 19, 2010 1:54 pm
Ok so would it be ok to run a blue coil and a empi pick up cuz I'm realy tired of droping a hundred dollars a pop on these things and this will make the 4 th or 5 th one
PostPosted: Mon Apr 19, 2010 4:46 pm
I would buy a Petronix. I think they have a 30 month warranty.
Also you need to run a ballast resistor with some of the electronic ignitions and a high voltage coil.
PostPosted: Mon Apr 19, 2010 5:42 pm
There is more than 1 blue coil.
You need the one that has 2.8-3.2 oms resistance.
If you are paying $100 for an Ignitor you are getting hosed.
PostPosted: Mon Apr 19, 2010 9:38 pm
realy they are a 128 with tax than 12.95 to ship them and yes my ass is chaped and jim a t jims custom vw told me to run the the bosch bule coil the better one of the two and the empi pick and i should never have another problem hopefuly :(
PostPosted: Tue Apr 20, 2010 3:40 pm
OK you gotta use some punctiation so I can decifer this.
You are paying $128 + $12.95 for shipping for an Ignitor points conversion kit?
1847A is the common part number for a Bosch 009 kit.
Is that what you are getting?
The coil you need to use has to have the 2.8-3.2 ohms of resistance.
There are several "Blue" coils. Check yours to be sure.
What is an Empi "pick"?
PostPosted: Tue Apr 20, 2010 4:44 pm
WOW! 140 bucks for a 40 dollar EMPI electronics points eliminater?
PostPosted: Tue Apr 20, 2010 8:44 pm
if your paying that much your ass is more than chapped.and i think they are two types of pertronix one is a 4 ohm and one is an 8 ohm i think,but make sure the coil matches the type of ignition,you can buy a complete 009 distributor and pertronix with a coil for what your paying.chad :mrgreen:
PostPosted: Wed Apr 21, 2010 12:06 am
Ok 109 for the compfires I've been buying but Jim at Jims custom vws set me up today with the right coil and a empi intitor running good than it's out of time now when I changed that do I have to rest my timeing sorry about all the spelling I'm on my iPhone and it blows
PostPosted: Wed Apr 21, 2010 12:18 pm
Anytime you change any part of the ignition system it is a good idea to check/reset the timing.
One other thing, put your points, condenser and a screwdriver in a bag under your passenger seat cover.
If the EMPI module fails at least you can trail fix it.
FWIW, this is the module I use and sell now.
One failure out of 35 I've bought in year or so.
Was replaced with no issues.
http://www.compu-tronix.com/VW009.htm
