It is currently Mon May 04, 2026 6:38 am
 Post subject: carb and or timing
PostPosted: Tue Apr 13, 2010 9:08 pm
i have a stock 34 pict-3 carb i turned the bypass srew out 2 turns and the volume srew out 1 1/2 turns. was running ok but not sure where they should be. bc i set the timing after was around 30 btdc set it at 7 but would not keep running moved to 10 then got better but still not wanting to idle. so i need some start setting or just some input. and the motor code is a H5 and i have a 009 if that means anything.
thanks guys
 Post subject: Re: carb and or timing
PostPosted: Wed Apr 14, 2010 12:51 am
Thats the trouble with an 009 they only work well with a 34pict when over advanced. If you find a dual port vaccum advance distributor the engine will run better due to more initial advance.
Well written carb adjustment article:
http://www.vw-resource.com/34pict3.html
PostPosted: Wed Apr 14, 2010 6:57 am
I have a few distributors in a box and I think one is the vacuum type and is new or barely used. I will sell and ship if you are interested. PM or e-mail and I will look more into it. Just an offer and trying to help. :wink:
PostPosted: Wed Apr 14, 2010 9:22 am
I forgot to menmtion to check the idle jet for dirt and the fuel shut off valve to see if it opens.
PostPosted: Sun Apr 18, 2010 3:46 pm
What did you find out?
PostPosted: Sun Apr 18, 2010 9:48 pm
i really had not had time to look at it to much. i did read that stuff you sent. help me alot, i did have it running alot better. but i rode it down the road and the belt came off some where and, i have not been able to get one. i think i may have some dirt some place bc sometimes stoping at lights it runs and ildes good and other times it acts like it not getting gas or to much not sure which.
