It is currently Mon May 04, 2026 8:42 am
 Post subject: it wont run !
PostPosted: Sat Apr 03, 2010 2:07 am
i was out ridin tonight (friday) and i ended up walkin home its not pumpin gas to the carb i dont think but my fuel pump is still makin the noise when i flip the switch on but its not fillin my lines full of gas cause i can tell from the fuel filter its a faucet <or somethin like that any imput on any more pumps or should i go buy another faucet
but i can spray starter fluid down the carb n it runs but it misses so what could it be
Brandon
 Post subject: Re: it wont run !
PostPosted: Sat Apr 03, 2010 2:14 am
can you run a stock pump?
PostPosted: Sat Apr 03, 2010 2:32 am
nahh my block dont have the place for a stock pump
Brandon
PostPosted: Sat Apr 03, 2010 2:52 am
we run a pump like this with no problems.
http://cgi.ebay.com/ebaymotors/low-pres ... ccessories
PostPosted: Sat Apr 03, 2010 9:12 am
Got gas in it? 8)
Blockage in the fuel line or at the pickup in the tank?
something wrong with the float needle n seat in the carb?
Is the pump louder than normal? Those facets get loud when there is no fuel in them.
PostPosted: Sat Apr 03, 2010 9:58 am
if got gas in it and gas to the pump but no gas out its a bad fuel pump.check to make sure its getting gas to it before you go buy a new pump.could be clogged off in the valve from the tank or plugged off in the inlet side of the pump.chad :mrgreen:
PostPosted: Sat Apr 03, 2010 12:41 pm
kybuggy1 wrote:
Got gas in it? 8)
yep its got gas in it, i took the line off from the pump to the gas tank and gas came out so i guess its the pump
Brandon
PostPosted: Sat Apr 03, 2010 12:44 pm
what do you mean inlet side of the pump? where the gas line goes from the tank? should i try to clean the fittings out to see if anythings in there
Brandon
PostPosted: Sat Apr 03, 2010 12:57 pm
sure check it to make sure there is nothing clogging it off,ive seen debri get in the fittings before and stop it up,one piece of rust aggrevated me for ever til i got it out.would run, not run,run, not run, it was a small piece of rust that had made it in there somehow.also have seen gas capps that stopped venting and it would pull a vacum and stop pumping but you should have noticed that it would have started working agian after you checked your gas.chad :mrgreen:
PostPosted: Sat Apr 03, 2010 1:02 pm
The slightest amount of debris will gum up a Facet pump. You need a good filter between the tank & pump.
PostPosted: Sat Apr 03, 2010 11:54 pm
ive got a 1/4 fuel filter between the tank and pump like your talkin about
nah i aint fooled with it anymore ive just been ridin my 4 wheeler ill start on it sometime this week
Brandon
PostPosted: Thu Apr 08, 2010 1:21 am
started workin on it today it was the fuel pump but i think its bout to go out cleaned it out real good and rode it about 15 mins and it done it again! it friggen quit so im just gonna do away with this buggy :x
Brandon
PostPosted: Tue Apr 13, 2010 3:27 am
got it fixed it was the damn fuel pump this whole time ive got a solex comin for it now i went with a mr. gasket pump this time around
Brandon
PostPosted: Tue Apr 13, 2010 8:54 pm
well it will be running again soon so you should just keep it :mrgreen:
