It is currently Mon May 04, 2026 6:48 am
PostPosted: Mon Mar 29, 2010 10:32 pm
Can anybody please help me identify these rear rotors! When i pulled my wheel off i found a big crack between the studs. I still have the piece but i would rather not have it welded because it is cast and my buggy does see a lot of street use as well as off road.Now keep in mind that these may have had some machine work done to them (eg: holes drilled, material removed, whatever.) I just need to know if there is something similar that will bolt up to the hubs. Any help is greatly appreciated, the calipers are not anything special basically the econo calipers. Please help me out.
PostPosted: Mon Mar 29, 2010 10:49 pm
Looks like standard 4 lug rotor with an adapter atached.
PostPosted: Mon Mar 29, 2010 11:03 pm
Could be a set of 914 rotors and drives. That's what I run.
PostPosted: Mon Mar 29, 2010 11:07 pm
If this is a standard rotor i have never seen one like it nor has some of my buddy's in the v dub world.As for the adapter there is not one, that is all one piece!The standard 4 lug brakes that i have seen are splined in the middle for the stub axle, this rotor bolts to a hub.
PostPosted: Tue Mar 30, 2010 5:18 pm
wide 5 rotors modified to bolt to a hub?
PostPosted: Tue Mar 30, 2010 5:23 pm
What's the PCD of the bolt holes and the centre bore?
I've a few disc libaries here.
PostPosted: Tue Mar 30, 2010 11:01 pm
I feel like an idiot asking this question because i probably should know this but what are you talking about when you say PCD.This is VW wide five pattern and don't seem to have been modified and they most likely are an older set up because the buggy has been around a while.Oh yea one more thing the hub on the trailing arm does have VW stamped on it! I really do want to get this sucker put back together and this is one of the things holding me up.
PostPosted: Tue Mar 30, 2010 11:33 pm
The top two pics look like the setup that was on my old buggy when I got it. I was told it was a some old volvo rotor slipped over a stock vw drum/hub that was turned down until there was nothing but the hub left. You could tell on my old rotors where they had reamed out the lug holes a lil to match the vw pattern. And I believe Nitro is right, the third pic shows just a 4 to 5 adapter added on.
PostPosted: Wed Mar 31, 2010 5:28 am
PCD = Pitch Circle Diameter
Diameter the centres of the holes are drilled on.
PostPosted: Wed Mar 31, 2010 8:09 am
isn't it just a turned down old drum with a hat? I used to drill all my rotors out like that! PITA!!! :mrgreen:
PostPosted: Wed Mar 31, 2010 9:26 pm
The Porsche 914 has the rotor hat and drive set up like that. That's what it looks like to me. I have the same set-up on mine, diferent adaptor plate.
PostPosted: Thu Apr 01, 2010 8:55 am
I agree with Mike. I had that setup on the Duck. The only difference was the Rotors were not drilled.
PostPosted: Fri Apr 02, 2010 2:26 pm
Ok my next question is what year and is it front or rear!I need this info so i can see if my local parts store can order this so i can look at it.
PostPosted: Sat Apr 03, 2010 7:14 am
http://www.thesamba.com/vw/classifieds/ ... ?id=834032 I don't know if this will help but here are some parts on the $amba. http://www.thesamba.com/vw/classifieds/ ... ?id=909098 Here is another 1. I had a set up like this on a Baja bug the P.O. had welded a 4 to 5 lug adapter to the rotor hat so he could run wide 5's all the way around and still use an IRS trans. Thanks Dave T
