It is currently Sun May 03, 2026 11:06 am
 Post subject: suby fuel pump help`
PostPosted: Sun Mar 21, 2010 8:02 pm
i took this set up out of a running car did all of the wiring my self put it back in and now the fuel pump relay wont work i have cheaked all the grounds and power over and over i can jump the relay and the pump works i have injector palse fire every thing but fuel help!!!
 Post subject: Re: suby fuel pump help`
PostPosted: Sun Mar 21, 2010 8:15 pm
Make sure you have the right kind of power going to the pump,,as in ACC not Start ,,,Hot when on. Also make sure your fuel lines aren't crossed.
PostPosted: Sun Mar 21, 2010 8:50 pm
Or you can just spend 5 minutes and clean out the jets... Ooops.. that will only work on an AC engine.. I forgot that you cannot trouble shoot a WC engine.. :twisted: :twisted:
PostPosted: Sun Mar 21, 2010 9:55 pm
the fuel pump will not power up when hooked to the comp. but when i bypass that wire the pump works fine but the pump runs all the time
PostPosted: Sun Mar 21, 2010 10:15 pm
Is the fuel pump relay clicking? Try disconnecting the battery overnight too.
PostPosted: Sun Mar 21, 2010 10:19 pm
Does the ecm provide power or ground to the relay and is the relay wired accordingly?
PostPosted: Sun Mar 21, 2010 10:20 pm
http://www.justanswer.com/view_image.as ... ubpump.gif
PostPosted: Sun Mar 21, 2010 10:27 pm
this is a 1994 ej2.2 set up
PostPosted: Sun Mar 21, 2010 10:32 pm
that diagram is obd1 only has 1 o2 sensor
PostPosted: Sun Mar 21, 2010 10:40 pm
its wired just like the digram the lg/b on D23 is the wire that is not working
PostPosted: Sun Mar 21, 2010 11:03 pm
Perhaps the ecu is bad. Might try another one.
PostPosted: Mon Mar 22, 2010 7:41 am
can the fuel pump run on the ing. switch or does it have to run on the comp.
PostPosted: Mon Mar 22, 2010 8:05 am
It needs the computer to tell it when to run.
PostPosted: Mon Mar 22, 2010 9:59 am
Check the relay, it should run off the ignition since it has a fuel return, as well.
PostPosted: Mon Mar 22, 2010 3:47 pm
Usually the comp. just earths the relay for the pump, so if the comp. is bad, the circuit is usually fused open and it runs all the time rather than never switching on.
PostPosted: Mon Mar 22, 2010 4:09 pm
If you can not figure out why it does not work from the ECU, I see no reason why you can not connect it to you Ignition circuit to run constantly. The system has a fuel regulator to maintain the proper pressure so it should not matter.
PostPosted: Tue Mar 23, 2010 1:34 am
not a terrible idea. although I would only use it for troubleshooting. in the long term, I think letting the ECU control the fuel pump is a much better idea.
Are you sure the ECU is turning on like it should? all power sources hooked up correctly? Do you have power to both yellow wires at the fuel relay?
The ECUs are much harder to damage than you might think. but not impossible. if you think the ECU is wired correctly, and the only issue is the fuel pump, hard wire and see if it goes. But I bet it's a larger issue.
Subaru wiring: NumbchuxConversions
PostPosted: Tue Mar 23, 2010 7:26 am
yes both yellow wires have power if i by pass the relay it will start and run but i would like it to run on the ecm so im still working on it cheaking every thing
PostPosted: Tue Mar 23, 2010 8:08 am
On my suby the comp grounds the relay, so make sure the relay is wired correctly
PostPosted: Tue Mar 23, 2010 5:09 pm
thats how mine is but no ground comes out im going to try another ecm i got to see if that works
PostPosted: Tue Mar 23, 2010 7:48 pm
Some suby 2.2 obd1 had a cluster of grounds that grounded to the engine. Double check your grounds too.
PostPosted: Tue Mar 23, 2010 7:59 pm
it was the ecm tried a new one it works great thanks for the all the in put
PostPosted: Wed Mar 24, 2010 1:23 pm
All else fails blame the computer, they don't care! :wink: :mrgreen: Glad you found it.
