It is currently Mon May 04, 2026 11:53 pm
 Post subject: #3 dead ???
PostPosted: Thu Mar 18, 2010 10:48 pm
need lil help guys,i run a 2180 and #3 isnt running at all at idle but will if in the gas a lil, i have NEW 44 webers and first thought maybe carb prob,i have went through carb completely i have fire and i have fuel and air i checked for manifold leaks with ether but dont seem to have a leak, i checked compression and #3 is 90 #4 is 120 #1 is 110 and #4 is 120. last year i had a compression ring broke on #3 and when i pulled the piston the ring fell apart,i couldnt feel or see any damage so i re rung #3and#4 last year.do you guys have any ideas or opinions that im not thinking of or maybe overlooking? or should i bite the bullet and buy new pistions and cylinders???
lets just ride
 Post subject: Re: #3 dead ???
PostPosted: Thu Mar 18, 2010 10:54 pm
I wonder if you got a crack in your head between the valves
PostPosted: Thu Mar 18, 2010 10:55 pm
Did u adjust the valves???? they will cause problems like that
PostPosted: Thu Mar 18, 2010 10:59 pm
i havent had the heads off since i re rung it last year, but i did check the valves and they are on the money.
lets just ride
PostPosted: Thu Mar 18, 2010 11:07 pm
I had to replace a head last spring. Mine was cracked betwwen the valves. It missed and hissed at low rpm's
PostPosted: Thu Mar 18, 2010 11:09 pm
thanks for the input wildcat, id be worth pulling it to find out.
lets just ride
PostPosted: Thu Mar 18, 2010 11:11 pm
no problem. I hope to ride with yall some this year, If I don't run out of steam working on the new buggy.
PostPosted: Thu Mar 18, 2010 11:38 pm
Remember, to lite off fuel with low compression you need a good hot spark. Too much fuel not getting burned, washes the oil out of your rings and looses compression.Also fowls plugs and wears cylinders and rings.Go fuel inj. w/c that loves 93 octane.
PostPosted: Fri Mar 19, 2010 12:04 am
OR....go MSD on your ac and get 6 sparks per revolution (below 3000rpm) that are all hotter than most OEM wc sparks available. :roll:
Anyways, back to your question. Are you 110% sure there is no junk in your idle circuit (not just the jet, the whole circuit)?? If so, you didnt mention pullin that sparkplug. DD is right by saying that plug could be compromised after riding a while with a problem in that cylinder. If neither of those are it,the cracked head theory could very likely be it. Might wanna check that cylinder for roundness , too. Sometimes they are egged when you get them brand new. (I think that is whats going on with Koko's motor right now. Pull the cylinder and hone it lightly and see if the hone skips any spots). Even Cima/Mahle sells us some junk sometimes any more.
PostPosted: Fri Mar 19, 2010 5:46 am
I think it may all be in the carbs, the idle jets take care of the range from idle all the way to around 3500 rpm then the mains take over, it is very important that they stay cleaned out, here's how the idles work with the mains...@=idles #=mains
1000 rpm @@@@
2000 rpm @@@#
3000 rpm @@##
4000 rpm @###
5000 rpm ####
You can see that the idles is almost completely phased out around 3500 rpm, that's why it runs when you give it gas, but not run at idle. Anytime you put on new or rebuilt set of carbs, it will always have idle circuit problems until it get all the way cleaned out, I don't care if you rebuilt them and put them on the buggy in the operating room because of the clean environment, it will do it and once its cleaned out, no more problems again.
You will also need a synchronizer to check and see if both cylinders is pulling the same amount of air as well, if not, you may have a broken pushrod cup on your rockers or just out of adjustment or a broken rocker shaft block. Let us know what you find out.
PostPosted: Fri Mar 19, 2010 6:05 am
If it was mine the first things Id try is clean the idle jet then swap the plug then the wire. If the problem persists Id dig deeper. Id check the dist. cap for corrosion of the terminal too.
PostPosted: Fri Mar 19, 2010 10:23 am
Mine done that last year and i ckecked everything to find out that the manifold gasket was sucked in the head on the back side where you couldnt see it i even sprayed caeb cleaner and didnt do anything.And it was #3 that did that to me. Hope you get it fixed
PostPosted: Fri Mar 19, 2010 5:21 pm
thanks for all the input guys,i forgot to mention i did pull the plug and swap it aswell as swap the wires. im gonna dig deeper this weekend and ill keep ya posted thanks
lets just ride
PostPosted: Fri Mar 19, 2010 5:29 pm
larry i pulled the idle jet and air mixture screw and gently blew through the idle curcuit. should i do something different?
lets just ride
PostPosted: Fri Mar 19, 2010 5:40 pm
Blast that thing with air. I had my fuel lione come apart on the inside and clog my carbs. I had to blast air through the mixture holes, idle holes and main holes to get them unblocked.
PostPosted: Fri Mar 19, 2010 6:17 pm
about 2 years ago i had the same problem with #2 cylinder. thought it was my carbs. everybody kept tellin me to clean the jets and take the carbs apart. and it turned out i had a week ignition. i put a msd set up on. and it solved the problem
dave
PostPosted: Fri Mar 19, 2010 10:19 pm
Bmoore, Like Dad said, I think it's probably somehting in your idle circuit. That day down there at Stony when your buggy was running like crap and we cleaned the idle jets out, I got a big turd out of the idle jet that goes to the number 3 cylinder. I'm having the same exact problem, just on the number one cylinder. Make sure you clean out the idle circuit as best as you possibly can, it may be the whole problem.
-Dakotah/koko
JeffClay wrote:
-Dakotah/koko
keep on keepin' on!!
PostPosted: Fri Mar 19, 2010 10:25 pm
had same prob. one time. took electronic off put points back on fixed it ,but try idle mixture flowlike they said.
PostPosted: Sat Mar 20, 2010 1:53 pm
i just found the problem guys,the brass machined part that goes in the carb that the air mixture screw and needle seats in was stuck on the mixture screw from factory i guess? i removed it from the screw and reinserted it in my carb and gently seated it with a punch. put it back together and fired her up and she is screaming on all 4 now!!! thanks to all for the input and help!!!!
lets just ride
