It is currently Mon May 04, 2026 1:46 am
PostPosted: Sun Mar 14, 2010 5:59 pm
I am fixing to do my steering and was wondering what joints to use ??? Heim. Ford, Int.
Also is Heim street legal??
Thanks
MoblMec
PostPosted: Sun Mar 14, 2010 7:17 pm
I run ford end and they work well. However, your arms will need to be reamed out to fit the ford ends
PostPosted: Sun Mar 14, 2010 7:47 pm
Same deal with the internationals, they are just a little bit larger then the fords.
PostPosted: Sun Mar 14, 2010 8:14 pm
heim joints. Half the effort to install them and much cheaper.
PostPosted: Sun Mar 14, 2010 8:16 pm
Ford gets used in the spindles to leave more meat in the spindle to hold it.
PostPosted: Sun Mar 14, 2010 9:47 pm
If I had to do mine again, I think I would go with Heim Joints..
The ford ends work well but I bent my spindle a few months ago and I had to replace my spindle. Unfortunately, that meant that I had to get my spindles reamed again..
PostPosted: Sun Mar 14, 2010 10:52 pm
Heims, do it right the first time and be done with it.
PostPosted: Mon Mar 15, 2010 10:06 am
I agree.
PostPosted: Mon Mar 15, 2010 9:34 pm
Besides right or wrong, its stronger and cheaper.
PostPosted: Wed Mar 17, 2010 12:29 am
amen!!! :mrgreen: :mrgreen:
PostPosted: Tue May 11, 2010 6:51 pm
Does anyone have a pic of the heim end? I have stock link pin spindles and would much rather use a heim end than ream for an international. I am using 2.5x1 arms and expect about 10" of travel. Will these work for me?
PostPosted: Tue May 11, 2010 8:26 pm
3/4" heims with mis alignment spacers will work just fine.
PostPosted: Tue May 11, 2010 10:15 pm
thanks! thats what I wanted to see
PostPosted: Wed May 12, 2010 1:43 am
Mike lets see the rest of the buggy. Did you change colors?
PostPosted: Wed May 12, 2010 8:15 am
That's Jim's buggy I rebuilt over the winter.
PostPosted: Wed May 12, 2010 8:52 pm
what size tie rod s are those? You mention using 3/4 heims with misalignment spacers but everywhere I find 3/4 heims the bung used to insert into the rod requires a 1 1/4" dom tube! Thats huge and yours really dont look that big. Any help?
PostPosted: Wed May 12, 2010 9:47 pm
Forget the bungs, get steel swedged radius rods. Cheap way to do it right.
http://www.speedwaymotors.com/Swedged-S ... ,2091.html
PostPosted: Mon May 17, 2010 9:17 pm
I got my parts today and mocked them up!
