It is currently Sun May 03, 2026 6:23 pm
 Post subject: balljoint to kingpin
PostPosted: Thu Mar 11, 2010 9:30 pm
I'm having some drums turned for the front of my buggy i have kingpin front end and all he has is balljoint hubs he said i could buy bearings that would go from balljoint hub to kingpin spindle just wondering if anyone has done this and if so where can i find the bearings to do it thanks
 Post subject: Re: balljoint to kingpin
PostPosted: Thu Mar 11, 2010 10:01 pm
The way I did mine was using Bettle rotors and (inner bearing)Timken 30205M 9\KMI and (outer bearing)
SKF 32004 X/Q. The races where the original bearings were will need to be machined to except the new larger races. Inexpencive front brakes for a link pin beam.
PostPosted: Thu Mar 11, 2010 10:07 pm
thank you
PostPosted: Fri Mar 12, 2010 2:29 am
just wondering is this the bearings i need http://cgi.ebay.com/ebaymotors/VW-BUG-G ... 0101237606
PostPosted: Fri Mar 12, 2010 7:25 am
According to their descripition, they will work.
PostPosted: Fri Mar 12, 2010 12:29 pm
Will the 6.70X15 v treads fronts mounts onto my spindle mounts i think they are 5x15 or would there be an advantage to go with cut hub and stock vw wheel if I'm not going to run front brakes at this time? thanks :D
