It is currently Mon May 04, 2026 12:53 pm
 Post subject: Needing 3 rib internals
PostPosted: Tue Mar 09, 2010 8:24 pm
I am currently looking for ring/pinion, super diff, drive flanges for regular bus axles. Interested in either stock 5.38 or higher gear ratios don't want to go all the way up to a 3.88 though.
PostPosted: Tue Mar 09, 2010 8:31 pm
i have a stock r&p that came out of a six rib if it will work
PostPosted: Tue Mar 09, 2010 8:40 pm
I think most six ribs were 3.88's, 4.12 or a 4.88 would really be ideal for wheel speed I will keep that in mind though. Thanks
PostPosted: Tue Mar 09, 2010 8:55 pm
ok hope you find what u need there
PostPosted: Tue Mar 09, 2010 9:05 pm
My buddies got a 3 rib without 3rd. runs great in all other gears. If interested let me know.
PostPosted: Tue Mar 09, 2010 10:26 pm
got one for $200 nvr been in a buggy came straight out of a bas. Everything works in it as far as i now. :roll: You can contact me at 6065478122 :wink:
PostPosted: Wed Mar 10, 2010 5:03 am
i believe the 3 rib is 5.38 and 5 rib is 4.86 and 6 rib is 4.57 or any one of them could have the rare 5.42 im not completely 100% on this but close and also the 1st, 2nd, 3rd, and 4th gears are the same "ratios" in all three trannys
