It is currently Mon May 04, 2026 12:18 pm
 Post subject: Tube Notcher
PostPosted: Tue Mar 09, 2010 2:45 pm
Anyone have any experience with this tube notcher from Summit?
Obviously would not hold up in a production environment but for occasional use.......
http://www.summitracing.com/parts/HCK-SPPIPE/
Mike
Got Honda?
 Post subject: Re: Tube Notcher
PostPosted: Tue Mar 09, 2010 4:18 pm
That unit is fine for the occasional use.
PostPosted: Tue Mar 09, 2010 5:19 pm
i think all of them are pretty much the same woodward , harbor freight , ext .... its the hole saw that realy counts !!!!!!!!!! jason
PostPosted: Tue Mar 09, 2010 6:03 pm
Well I disagree on that one. You can spend anywere fron 30 to 300 on a drill driven notcher and you do get what you pay for. I looked around and decided that the cheaper ones were not for me and did not want to spend the higher dollars so this is my version of a Notcher:
PostPosted: Tue Mar 09, 2010 6:06 pm
nice use of a rotory table and a rather large angle plate. good idea steve.
PostPosted: Tue Mar 09, 2010 6:12 pm
hey steve, you think this table would work??? http://akroncanton.craigslist.org/tls/1628062380.html
:twisted: :twisted:
PostPosted: Tue Mar 09, 2010 8:15 pm
That's what I use, that or a lathe.
PostPosted: Tue Mar 09, 2010 8:38 pm
ok smarty pants made me eat my words ...you happy now :cry: :cry: i was talking about the small portable notcher but i like your way better !
PostPosted: Tue Mar 09, 2010 8:51 pm
here is the one i use. i do agree a quality hole saw makes a difference.lenox or ridgid work well. tap magic cutting oil or wd40 helps prolong the life. whatever is within reach at the time.
- Sigmund Freud
- Antonio Meloni
PostPosted: Sat Apr 03, 2010 1:29 am
OK don't know what happened but, it has done this before. I go to post a picture, the image is to large. Can't back up and the posts just run over top of each other and my message is gone.
Any way it would be nice to have a milling machine and a lathe. However a my cheap tube notcher in a drill press works. Mine is like the first pictured but had to shim the pipe clamp an 1/8" , now the hole saw goes straight through and blade is holding up fine. It may not be for production, but this is just my hobby.
PostPosted: Tue Jul 13, 2010 10:21 pm
I notch with a chop saw Its easy and less time
PostPosted: Wed Jul 14, 2010 2:40 pm
This one work pretty good. Its what I use.
PostPosted: Sat Jul 31, 2010 11:35 pm
I use a harbor fight notch-er for simple cuts 90's or 45's but I use this web site for all the rest. You just print it out rap the tube , mark it and cut with a cut off wheel.
http://metalgeek.com/static/cope.pcgi
|....BUDWEISER......| ||'|";, ___.
|_..._..._______===|=||_|__|., ] -
