It is currently Mon May 04, 2026 10:49 am
 Post subject: 3x3 arm Q?
PostPosted: Thu Mar 04, 2010 12:12 pm
guys i know this is going to sound stupid but< i dont know. 3x3 - what exactly does that mean...3" wider and 3'' longer? if so does that mean that if you have a frame that is 100" WB stock that if you use these 3x3 trailing arms it becomes 103" WB????? thank you Jim :?
 Post subject: Re: 3x3 arm Q?
PostPosted: Thu Mar 04, 2010 12:15 pm
All correct.
PostPosted: Thu Mar 04, 2010 2:24 pm
The width allows you to run wheels with 5" backspace & take stress off the stub axle bearings & the length transfers weight forward & gives you the ability to climb much steeper hills without going over backwards as well as adding additional ground clearance.
PostPosted: Tue Mar 23, 2010 10:40 am
Ok guys i am just learning also so how do the angles change on the axle shafts and what do you do to correct that.
PostPosted: Tue Mar 23, 2010 10:49 am
Use 930 CVs and axles. Leave the angles alone. The only way to correct the angles is move the engine/Trans back. Not worth the hassel for 3 x 3. It also defeats part of the reason to use 3x3 arms. Moving weight ahead of the wheel centerline.
