It is currently Sun May 03, 2026 6:17 pm
PostPosted: Sun Feb 28, 2010 9:29 am
i am centering my factory steering box and was wondering if you guys could post some pics of your setup . curios were you guys are running the swivel joints for the steering bar to make the turn to the box ! thanks for any help . jason
PostPosted: Sun Feb 28, 2010 5:53 pm
I put my universals right on the gear box, and right under the bar that holds the short steering wheel shaft.
If I remember right, you're trying to put an S-10 gear box on your buggie. How's it coming along?
PostPosted: Sun Feb 28, 2010 6:25 pm
I need that same setup.What size universals do i need? Going to s-10 box as well. Love the setup, just need it centered b4 i can add long arms.
PostPosted: Sun Feb 28, 2010 9:36 pm
hey dave , i was going to do the same setup as yours the cherokee gearbox and tracker pump and the double pully but my tracker pump was locked up from sitting and still would need to buy the double pully from you so i have two cherokee boxes sitten there i just thought to save a little money ill just center the factory vw box and run some u joints . the arms tuned out great ill give you a buzz this week to get you stuff back to you ! thanks again , jason
