It is currently Mon May 04, 2026 6:45 am
 Post subject: Fuel cell installation
PostPosted: Wed Feb 17, 2010 10:01 pm
Ok, going to try this Fuel Cell out. But it has 3 places for conections. one of the bottom ones for supply. Then bottom or top for return? And do I just want to plug the third?
PostPosted: Wed Feb 17, 2010 11:46 pm
Just cap the extra with an AN cap. Make sure you vent it.
PostPosted: Thu Feb 18, 2010 12:02 am
Your not going to like that cap. No one seems to listen. :? Water and dirt in and gas out, no way around it.
Make sure you have a roll over vent for it.
PostPosted: Thu Feb 18, 2010 12:38 am
Ok the top port with plastic on it is rollover vent, other 3 are just open. How do i vent it?
PostPosted: Fri Feb 19, 2010 11:24 am
No one knows how I should plumb this? Ok, I'm not buying it, someones holding out on me.
PostPosted: Fri Feb 19, 2010 11:35 am
I would run a line up a frame tube and loop it down and Install a small inline fuel filter on the end to keep dirt out.
PostPosted: Fri Feb 19, 2010 11:40 am
Thanks Steve. Ok, vents covered. Which one should I use for return? Bottom or top? Then I plug the leftover i guess :roll:
PostPosted: Fri Feb 19, 2010 12:23 pm
Top is return, bottom is outlet, other bottom can be used for supplement fuel supply system for use with big nitrous kit.
Put you a 400hp Big Shot on it, then you can use all three ports of your fuelcell. :mrgreen:
And Madmike aint joking about that lid. Lets water in. Seen it happen on a buddys drag car when he let his kids wash it :roll: :lol: .
PostPosted: Fri Feb 19, 2010 12:50 pm
I have my supply and return both on bottom :|
PostPosted: Fri Feb 19, 2010 12:53 pm
Ok, do I have any mod options? Or just want to cover it to protect it from the elements? And it has the rollover vent.
PostPosted: Fri Feb 19, 2010 1:17 pm
Ive got a pair of these 4 gallon cells for the single seater. I was going to put shower caps on them to keep crap out. Maybe you can duct tape plastic over the cap.
PostPosted: Fri Feb 19, 2010 1:24 pm
Thinking of a diamond plate lid, this is going to be in a trunk. Yes Larry, more weight :mrgreen:
PostPosted: Fri Feb 19, 2010 8:21 pm
http://www.summitracing.com/parts/SUM-290193/?rtype=10
something like this, mike has posted it a trillion times, everyone and their mother should be aware!! plus those caps that are on it are a royal pain in the ass, the gasket always slips and the caps get stuck, the plastic snaps on the levers, yadda yadda yadda
PostPosted: Fri Feb 19, 2010 9:48 pm
good info
PostPosted: Fri Feb 19, 2010 10:33 pm
Thanks Jeff.
PostPosted: Sat Feb 20, 2010 1:25 am
Got the link saved, thanks guys.
PostPosted: Wed Feb 24, 2010 11:21 am
Damn Nitro, I guess you're trying to get some bling bling! That is a nice-looking cell, I use a 8-gallon cell and it only has 3 ports in it, I used the top for a vent and the bottom 2 for supply and return. The vent uses a -6an fitting and the bottom 2 uses a -8an fitting, I bought me a new one and it is a natural finish instead of black and I can see how much fuel I have in the cell without worrying about running out, I only ran out one time and it sucks really bad where it happened at too. The cap is a pain sometimes and I modified it to make it easier to remove and added extra gasket to help keep the debris out, I usually only put fuel in it when the buggy is clean and you will also need to run a good in-line filters as well, I have 2 in-line for my supply, one is a 10 micron and the other is a 1 micron, I never had a jet or any carb problems since I ran this setup, make sure you put some shut-off valves for your supply and whatever you are going to use the other port on the bottom for. What pump are you running??
PostPosted: Wed Feb 24, 2010 11:25 am
I run a cadilac pump of some sorts. This tan has a sending unit so I will end up hooking up a fuel gage :mrgreen:
PostPosted: Wed Feb 24, 2010 11:31 am
nitro_mudder wrote:
I run a Cadillac pump of some sorts. This tank has a sending unit so I will end up hooking up a fuel gauge :mrgreen:
If you're going to use a gauge, use a ohm meter to check the resistance of the metering device full and empty and that way you will know what gauge to get, they make all kinds of different gauges depending on the make of the vehicle, it should tell you what kind to get with the paper the cell came with.
PostPosted: Wed Feb 24, 2010 11:43 am
Well no paper, I'll ohm it out with my fluke. Thanks chad.
p.s. get your arse down to stony lonsome :mrgreen:
PostPosted: Wed Feb 24, 2010 11:55 am
I could go, but will to bring my 4-wheeler that damn near tore my knee off, so the 4-wheeler is out of the question :oops: :lol: :lol: My buggy is not ready yet :oops: :oops:
PostPosted: Wed Feb 24, 2010 8:39 pm
Those cells use a GM gauge. I think its 0-90 ohm's
PostPosted: Fri Mar 05, 2010 8:14 pm
It has the gm sending unit in it, 0 - 90 ohms, 0 ohms empty 90 ohms full.
