It is currently Tue May 05, 2026 5:21 am
 Post subject: what cables to use?
PostPosted: Tue Feb 16, 2010 7:35 pm
im close to hookin up my tranny and throttle. i need cables and the hardware. what and where can i buy it at?
 Post subject: Re: what cables to use?
PostPosted: Tue Feb 16, 2010 8:35 pm
It all depends on the amount of money you want to spend...
Most of my buggy have used cables from a hardware store with wire clamps. I have always used steel brake lines to run the cables thru.
On my latest rebuild, I added a hydraulic clutch and a Morse throttle cable. I really like the Morse cable but I have heard a lot of people do not like the Morse Cable.
PostPosted: Tue Feb 16, 2010 10:56 pm
I dont like running the throttle cable through a tube. It gets jammed up with mud & debris. I always weld eyelets along my frame & run the cable through them. Usually 3 is all I need to route the cable. I have done this for almost 20 years and never had a failure yet. This method leaves the cable exposed & as long as the eyelets are placed in the spots you need to redirect the cable there is nothing to gum things up.
I always used the eyelets you bolt in since they have no sharp edges.
You can bolt them in but I like to weld them to keep em in place. I usually run wire rope from Lowes since its cheap. Most Lowes sell a ferrule that you loop the cable & slide both ends through & crimp it which is perfect for the throttle pedal end.
Total cost including eyelets is about 10 bucks. I usually run 1/16th which is overkill but lasts forever. Make up a second cable & keep it in your tool box. Youll never need it but its cheap insurance. Use a length of 3/8" brake tubing to pass the cable through your fan shroud. usually 4 inches is plenty. Just remember to avoid sharp edges so the cable doesnt wear on it.
If you are going to run a clutch cable use a stock VW cable & a cable shortener that buggy shops carry. I use the stock Bowden tube to redirect the cable at the trans.
PostPosted: Tue Feb 16, 2010 11:49 pm
i used a semi trl roll door cable,works perfect but not easy for everyone to get.dbn idea sounds easier
lets just ride
PostPosted: Wed Feb 17, 2010 2:56 pm
yeah for the crips, good idea but i dont have a nicropress tool. i may be able to find one. how do you all secure the wires to the pedal assemble?
PostPosted: Wed Feb 17, 2010 3:12 pm
Usually Lowes has the crimp tool there in the wire rope dept. I make my loop there & crimp the connector before I leave the store. I make a loop about the size of a nickel & I run washers on both sides of the loop with double nuts to keep them in place. That bolt then threads into my pedal & I put another nut on the back to secure it. Heres the order.....I use a 1 1/4" long grade 8 bolt. I put a washer on it then the cable loop then another washer followed by double nuts leaving just enough slop so the loop doesnt bind. Then I screw this into the threaded hole in the pedal & put a nut on the back to tighten it well.
PostPosted: Wed Feb 17, 2010 9:01 pm
I youes 3to4 eyelets also & heavy duty throttle cable from Drews
PostPosted: Wed Feb 17, 2010 9:22 pm
I have used cables with the crimp connectors. I have never used a tool to crimp them. I have a short section rail road track that I place it on and beat it with a small sledge hammer. Hasn't failed me yet.
PostPosted: Wed Feb 17, 2010 11:39 pm
You have heard of the right tool for the job? :D
PostPosted: Thu Feb 18, 2010 12:43 am
LOL, I thought i was ussing it.
PostPosted: Thu Feb 18, 2010 1:33 am
i have always used wire cable from Tractor Supply. run it in 5/16 break line. the trick to keeping it from binding with crap in the line it to use a much larger tube than cable, and run the break line as close to the throttle peddle and carb set-up as possible. it will cost you like $15 to set up a nice clean lookin throttle cable that will last as long as your buggy.
PostPosted: Thu Feb 18, 2010 11:52 am
K I got a nicropress tool from school. So make my own throttle cable and buy a clutch cable
