It is currently Tue May 05, 2026 1:59 am
PostPosted: Thu Feb 04, 2010 10:05 am
The only post I found is Rockrockets failed one. Ive got 2 of these nearly new so I have a backup. Its supposed to be as hot as an MSD which is a plus & I always carry a 009 & Bosch coil so if they both fail I can get out of the woods. Has anybody other than Rock used one & liked it?
PostPosted: Fri Feb 05, 2010 9:20 am
Great.....I have the one ignition nobody has any experience with??
PostPosted: Fri Feb 05, 2010 4:39 pm
dont feel bad no one responds to my pots either, of course a lot of them have met me,,,, hmmmmm. oh and the igntion, no idea.
PostPosted: Fri Feb 05, 2010 5:27 pm
u mean nobody on curts site can help you...ahhh. hahaha :roll:
PostPosted: Fri Feb 05, 2010 5:36 pm
That's a good idea, ask curt I'd bet he knows or can find out.
PostPosted: Sat Feb 06, 2010 11:50 am
Considering how FAMILIAR the names on the members list sounds thats a good idea. Maybe a bunch of strangers hijacked everyones user name & avitar.....HMMMM
PostPosted: Sat Feb 06, 2010 7:54 pm
PostPosted: Sat Feb 06, 2010 9:51 pm
is it a module inside the distributor, or is it a whole compufire setup control box wires pickup...etc?
PostPosted: Sat Feb 06, 2010 10:05 pm
It has a cap that snaps on in place of the rotor & cap & sends a signal to the 4 coils.
PostPosted: Sat Feb 06, 2010 10:54 pm
Sounds like a pretty high dollar setup. if it has four coils that's some pretty hot spark. I don't see how that can't be good. I'll bet you never gas foul a spark plug! :!:
PostPosted: Sun Feb 07, 2010 11:21 am
Mofoco sells em for 200 bucks. Its supposed to put out 60,000 volts & for that money its a great deal. Its supposed to be run at Baja & takes the punishment so I guess Ill give it a shot.
PostPosted: Sun Feb 07, 2010 11:31 am
If it's good enough for baja its got to be good for buggies! Keep us posted if you run into any trouble, but it sounds like a good setup for a good price. What does a msd setup of this magnitude cost?
PostPosted: Sun Feb 07, 2010 12:13 pm
I have one. never put it on . very good they say . Going to put on my new motor this spring .Let me know how it works hopefully very well
PostPosted: Mon Feb 08, 2010 11:06 pm
my buddy has one, personally im not too impressed with it. he did burn out one coil pack on it. buit he says he likes it alot. i dont know, i will stick with my msd
Dave
PostPosted: Mon Feb 08, 2010 11:23 pm
Ive never priced the MSD out but for the distributor, coil & box new its got to be at least 500 bucks Id say.
PostPosted: Tue Feb 09, 2010 1:31 am
im running the module inside the distributor and so far so good.
lets just ride
PostPosted: Tue Feb 09, 2010 6:21 pm
i think buggyb runs one, he never gets on here, but he builds a lot of our motors and trannys.. i think he likes it.
PostPosted: Wed Feb 10, 2010 1:33 pm
hey jeff i do get on here some times and yes i do have a dis-ix i have ran all kinds of ignitions and compu-fire has been the best it buns great plugs look great much better throttle response.
PostPosted: Wed Feb 10, 2010 2:46 pm
Perfect. thats what I needed to hear was somebody who runs it & says it works well. Ill give it a shot. I can always change it if I have problems.
PostPosted: Thu Feb 11, 2010 12:31 pm
i do not run this ignition. i have run compu-fire pointless and hated it. it was the hardest starting pos ever. why run anything but a 009? they work great and they are simple as hell. simplisity is bliss with the VW's! Iwas told once that the best ignition is acually a factory unit. it is like a 009 but has 2 sets of points in it. my uncle runs one of these, he was offered any ignition at appletree at silverlakes for it! so why add bunches of wires and crap for a big red distributor cap and a neat looking coil when it really gets you nowere?
PostPosted: Thu Feb 11, 2010 1:06 pm
Ive got 2 of them.....for free. I actually prefer a 009 with points & a blue coil. I just figure Ill try it out.
PostPosted: Thu Feb 11, 2010 1:10 pm
because a hotter ign. will get you somewhere...my msd was a night and day difference no sure on the compu-fire tho. but im sure it will do good....simple as points- not even close, better then points- by far..run with it DbN an let us kno how it works out. i almost bought one before the msd so im just a lil curious
PostPosted: Thu Feb 11, 2010 1:19 pm
Im hoping for good results. It uses a 009 as a base. The rotor is replaced by a magnetic trigger that sends a signal to each of the four 60,000 volt coils. Rather than 1 coil cycling to provide all the spark you have 4. That should mean more voltage due to the load being divided by 4. A single coil drops output at high rpm because it cant keep up.
PostPosted: Thu Feb 11, 2010 1:56 pm
you will like it my engine runs a little cooler and you can retard timing a few degrees i think it is better than msd and you do not have all those wires and big box to keep dry
