It is currently Mon May 04, 2026 11:11 am
 Post subject: winch
PostPosted: Fri Oct 05, 2007 6:25 pm
What size winch do you guys use? I have a 4 seat buggy just looking for some ideas i was looking at a 3000 pound . wondering if that would be ok.
DAREK
PostPosted: Fri Oct 05, 2007 7:51 pm
4000 warn works great, only if you keep the motor running.drains the battery fast if not running.
PostPosted: Fri Oct 05, 2007 8:42 pm
I had a "Ramsey" 3500lb winch I thought it would be fine for a buggy big mistake in my opinion. #1 Ramsey SUCKS ! where the winch mounted was made of some form of plastic looking crap, which broke loose from the actual whinch. #2 I was stuck......but not bad I was giving the buggy full power with excellent traction, but the winch broke due to some sub standard money saving crap that should have held it together.All of my mounts held fine but the actual bolts pulled out of this whinch.......SO I swaped to the one from my older truck which is a mile marker 8000lb, I haven't had a problem yet.
Just don't choose ramsey unless you would like to have a $ 400.00 paper weight. ( 8000lb mile marker is the same $$$$$$ )
just my opinion,
Bruce
PostPosted: Fri Oct 05, 2007 8:49 pm
Double the weight of your rail and that is the size I would go with.
The Wild Kids
PostPosted: Fri Oct 05, 2007 10:57 pm
i use the warn 4.0ci, my buggy is around 1650-1700lbs. on a single pull(cable to a tree) i usually help it along by feathering the clutch. for extra heavy pulling power get a snatch block, by doubling up (cable to the snatch block/tree then back to buggy) you are doubling the pulling capasity.(according to warn)
- Sigmund Freud
- Antonio Meloni
Users browsing this forum: No registered users and 9 guests
